after freeze ssh dont connect. i try tommorov check log with uart connect.
Totally un-related to the topic. Yes Selling Free Software - GNU Project - Free Software Foundation but source for most CE components will be required. They don’t have to give you the source to their scripts or custom built dts files.
I’ve done a hard reset and gone back to basic Estuary skin and it is back to being stable from what I can tell. I just have Jellyfin, iplayer, vnc viewer and a few other add-ons now.
All my shares are smb/cifs.
I had been using Aeon Tajo skin and was getting lots of errors from Embuary helper and occasional TMDB errors. I had it all configured to look nice and make it easier to browse movies and tv library. The basic setup is okay, I’ll just go back to using Yatse to browse the library.
