CoreELEC 20.3-Nexus Amlogic-ne Discussion
For me it was the same. Since yesterday, it says that there is an update, but nothing happens afterwards. In previous versions, after this message, the update file was downloaded and a message appeared asking for permission to apply it.
So, I downloaded the ne.aarch64 file from GitHub, I put it in the Update shared folder, I rebooted and the patch was applied. Now I have the 20.3-Nexus ne.aarch64 installed.
It seems there is a problem in the update procedure…
Thanks for your work!!
Hi guys!
Nice job, but when i tried to use a nvme as internal storage, does not appears, I have a vim4 with the new mx2 extension, where is the configuration settings to enable nvme? Or do I mount it by cli?
thnks
I don’t think this (PCIe) is supported but maybe I’m wrong.
i ask because appear in the news:
 * Amlogic-ne: added support for PCI
So, I’ve had my HK1rBox S905X4 a few weeks now, still has the stutters after pausing some times, but the main issue is freezing. Was just watching The Office, binging, and after 5 episodes, mid episode screen went black and system froze. Half the time I click reboot kodi or shut down, it hangs at that screen and does nothing.
Beelink with v18, maybe once every 3 months it might lock up, and 9/10 times if you waited a minute it would just reboot itself. This one, froze on reboot once, screen went black and froze once, and another episode just quit after playing and didn’t go to the next episode (had play all for folder) and didn’t freeze, but just quit and back to the main screen.
Been very flakey for me.
Does v19.x work on this box? will it possibly be more stable for me? Should I try a nightly? I went from such a solid performing box, to daily issues, it’s kinda depressing. I just wanna watch TV. :smiley:
Sometimes it is the media/Office Binge
Same issue with other shows/Movies/ media in your library ?
All versions of CoreELEC will work on Hk1x4
Try Nexus Stable
Or Latest Nightly Nexus .ng
4.9 Kernel
On H96Max-x4 Using CoreELEC-Amlogic-ng.arm-19.5-Matrix-Generic.img works fine.
However when I installed (fresh) CoreELEC-Amlogic-ne.aarch64-20.3-Nexus-Generic.img av1 decoder failed, once I play av1 video the whole HDMI fails - no signal on screen - I’ve to restart kodi on ssh.
Playing h264 videos is fine.
On both systems I’m using s905x4_4g.dtb image.
As a new user I cannot upload log file, so
Feb 02 21:07:58 ELEC kernel: hdmitx: audio: Audio Type: PCM
Feb 02 21:07:58 ELEC kernel: hdmitx: hw: set audio
Feb 02 21:07:58 ELEC kernel: hdmitx: hw: hdmitx audio_param->channel_num = 1, hdev->aud_output_ch = 33
Feb 02 21:07:58 ELEC kernel: hdmitx: fs = 2, cd = 6, tmds_clk = 148500
Feb 02 21:07:58 ELEC kernel: hdmitx: hw: aud_n_para = 6272
Feb 02 21:07:58 ELEC kernel: hdmitx: hw: set channel status
Feb 02 21:07:58 ELEC kernel: hdmitx: hw: [0x10e3] = 0x1f
Feb 02 21:07:58 ELEC kernel: [drm] drm hdmitx hpd notify
Feb 02 21:07:58 ELEC kernel: [drm] meson_hdmitx_hpd_cb[1993]
Feb 02 21:08:19 ELEC kodi.sh[2111]: codec_init amstream version : 2.0
Feb 02 21:08:19 ELEC kernel: VID: VD1 off
Feb 02 21:08:19 ELEC kernel: the vdec clock on, ref cnt: 1
Feb 02 21:08:19 ELEC kernel: the clk_hevcf_mux clock on, ref cnt: 1
Feb 02 21:08:19 ELEC kernel: the clk_hevcb_mux clock on, ref cnt: 1
Feb 02 21:08:19 ELEC kernel: hevc mux clock is 499999992 Hz
Feb 02 21:08:19 ELEC kernel: hevc back mux clock is 499999992 Hz
Feb 02 21:08:19 ELEC kernel: the pwrc-hevc power on
Feb 02 21:08:19 ELEC kernel: vdec_create instance 000000002aa7f604, total 1, PM: power-domain
Feb 02 21:08:19 ELEC kernel: vdec_init, dev_name:ammvdec_av1, vdec_type=VDEC_TYPE_FRAME_BLOCK, format: 16
Feb 02 21:08:19 ELEC kernel: [0]vdec_is_support_4k() 1 max_pic_w 3840 max_pic_h 2160 buffer_spec_index 1 work_buf_size 0x510000
Feb 02 21:08:19 ELEC kernel: [0]no_head 0 low_latency 0, signal_type 0x0
Feb 02 21:08:19 ELEC kernel: decoder_bmmu_box_alloc_box, tvp_flags = 0
Feb 02 21:08:19 ELEC kernel: av1: ver (201602101,0) decinfo: 3840x2160 rate=1600
Feb 02 21:08:19 ELEC kernel: After aom_bufmgr_init, prev_fb_idx : -1, new_fb_idx : -1
Feb 02 21:08:19 ELEC kernel: av1_local_init: alloc ucode log buffer 0000000076c14098
Feb 02 21:08:19 ELEC kernel: [TEE], the fw (av1_mmu) will be loaded…
Feb 02 21:08:19 ELEC kernel: hevc mux clock is 799999988 Hz
Feb 02 21:08:19 ELEC kernel: hevc back mux clock is 799999988 Hz
Feb 02 21:08:19 ELEC kernel: hevc video changed to 4096 x 2048 60 fps clk->800MHZ
Feb 02 21:08:19 ELEC kernel: vfm map vdec-map-0 created
Feb 02 21:08:19 ELEC kernel: ppmgr local_init
Feb 02 21:08:19 ELEC kernel: dim:ch[0]:event:8:_REG
Feb 02 21:08:19 ELEC kernel: dim:reg:use[0]ms
Feb 02 21:08:19 ELEC kernel: dim:ch[0]:event:3:_START
Feb 02 21:08:19 ELEC kernel: vdec_init, vf_provider_name = vdec.av1.00
Feb 02 21:08:19 ELEC kernel: vdec_init, inst_cnt = 12, port type 0xd11
Feb 02 21:08:19 ELEC kodi.sh[2111]: [codec_pause]p->has_audio=0
Feb 02 21:08:19 ELEC kodi.sh[2111]: video_pause!
Feb 02 21:08:19 ELEC kernel: vdec->port_flag=0x102, port_flag=0x103
Feb 02 21:08:19 ELEC kernel: [0]av1 cached=12288 need_size=12288 speed= 28 ms
Feb 02 21:08:19 ELEC kernel: dim:value reg:ch[0]:fix_buf:0;ponly <0,0>
Feb 02 21:08:19 ELEC kernel: dim:ch[0]:bypass change:n:0->1:0x4
Feb 02 21:08:19 ELEC kernel: dim:3840x2160-0x501000.
Feb 02 21:08:19 ELEC kernel: dim:di_reg_setting:ch[0]:for first ch reg:
Feb 02 21:08:19 ELEC kernel: cal_dur_from_pts inner driver dur1600
Feb 02 21:08:19 ELEC kernel: detect vout mode change!!!
Feb 02 21:08:19 ELEC kernel: [tsync_avevent_locked 827]VIDEO_START-tsync_mode:0(S)
Feb 02 21:08:19 ELEC kernel: pcr:0x0,param:0x0,vpts:0x0,apts:0xffffffff
Feb 02 21:08:19 ELEC kernel: video_send_uevent: VIDEO_FORMAT=1, ret=0
Feb 02 21:08:19 ELEC kernel: [drm] am_meson_drm_fb_helper_set_par IN
Feb 02 21:08:19 ELEC kernel: [drm] am_meson_drm_fb_helper_set_par OUT
Feb 02 21:08:19 ELEC kernel: [drm] [meson_hdmitx_encoder_atomic_disable]
Feb 02 21:08:19 ELEC kernel: [drm] am_meson_crtc_atomic_disable-[0]:in
Feb 02 21:08:19 ELEC kernel: hdmitx: edid: not find mapped vic
Feb 02 21:08:19 ELEC kernel: [drm] meson_hdmitx_encoder_atomic_mode_set: enter
Feb 02 21:08:19 ELEC kernel: [drm] meson_hdmitx_choose_preset_mode validate vmode 2560x1440p60hz, 0
Feb 02 21:08:19 ELEC kernel: [drm] build_hdmitx_attr_str:444,10bit = 2+10
Feb 02 21:08:19 ELEC kernel: [drm] build_hdmitx_attr_str:422,12bit = 1+12
Feb 02 21:08:19 ELEC kernel: [drm] build_hdmitx_attr_str:rgb,10bit = 0+10
Feb 02 21:08:19 ELEC kernel: [drm] build_hdmitx_attr_str:444,8bit = 2+8
Feb 02 21:08:19 ELEC kernel: [drm] build_hdmitx_attr_str:rgb,8bit = 0+8
Feb 02 21:08:19 ELEC kernel: [drm] meson_hdmitx_decide_color_attr get fmt attr [0]+[8]
Feb 02 21:08:19 ELEC kernel: [drm] meson_hdmitx_choose_preset_mode update 2560x1440p60hz expect 0
Feb 02 21:08:19 ELEC kernel: [drm] am_meson_crtc_atomic_enable-[0] in: new[2560x1440p60hz], old[1080p60hz], vmode[4-4], uboot[0]
Feb 02 21:08:19 ELEC kernel: [drm] am_meson_crtc_atomic_enable-[0]: enable mode 2560x1440p60hz final vmode 0
Feb 02 21:08:19 ELEC kernel: [drm] am_meson_crtc_atomic_enable-[0]: out
Feb 02 21:08:19 ELEC kernel: [drm] [meson_hdmitx_encoder_atomic_enable]
Feb 02 21:08:19 ELEC kernel: hdmitx: hdmitx_set_current_vmode[6021]
Feb 02 21:08:19 ELEC kernel: hdmitx: system: recalc before 2560x1440p60hz 60 1, frac 0
Feb 02 21:08:19 ELEC kernel: hdmitx: system: recalc after 2560x1440p60hz 60 1, frac 0
Feb 02 21:08:19 ELEC kernel: hdmitx: system: get current mode: 2560x1440p60hz
Feb 02 21:08:19 ELEC kernel: hdmitx: system: update physical size: 700 390
Feb 02 21:08:19 ELEC kernel: hdmitx: check failed vic: 793
Feb 02 21:08:19 ELEC kernel: DOLBY: vout_notify_callback: VOUT_EVENT_MODE_CHANGE
Feb 02 21:08:19 ELEC kernel: [drm] meson_vout_update_mode_name: hdmitx update vout 1 name 2560x1440p60hz.
Feb 02 21:08:19 ELEC kernel: [0]change to calc dur 1600, old dur 1600
Feb 02 21:08:24 ELEC kernel: hdmitx: system: irq 4 0
Feb 02 21:08:24 ELEC kernel: hdmitx: UTC+0 2024-02-03 21:08:24 HPD LOW
Feb 02 21:08:24 ELEC kernel: hdmitx: system: plugout
Feb 02 21:08:24 ELEC kernel: hdmitx: hdmitx_set_hdr10plus_pkt: null vsif
Feb 02 21:08:24 ELEC kernel: [RX]-up_phy_addr = 0
Feb 02 21:08:24 ELEC kernel: hdmitx: system: update physical size: 16 9
Feb 02 21:08:24 ELEC kernel: [drm] drm hdmitx hpd notify
Feb 02 21:08:24 ELEC kernel: [drm] meson_hdmitx_hpd_cb[1998]
Feb 02 21:08:25 ELEC kernel: hdmitx: system: irq 2 0
Feb 02 21:08:25 ELEC kernel: hdmitx: UTC+0 2024-02-03 21:08:25 HPD HIGH
Feb 02 21:08:25 ELEC kernel: hdmitx: system: plugin
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: EDID Parser:
Feb 02 21:08:25 ELEC kernel: [RX]-up_phy_addr = 2
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: get dtd0 vic: 16
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: get dtd1 vic: 31
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: get dtd2 vic: 4
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: get dtd3 vic: 793
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: find IEEEOUT
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: check sum valid
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: blk0 raw data
00ffffffffffff005a6335e601010101211e0103804627782e1545a6544a9d23
0e5054bfef80e1c0d140d100d1c0b3009500818081c0565e00a0a0a029503020
3500ba892100001a000000ff005639573230333334323434330a000000fd0018
4b0f711f000a202020202020000000fc005658333237362d5148440a20200116
Feb 02 21:08:25 ELEC kernel: hdmitx: edid: blk1 raw data
020333f15b010203040506070e0f901112131415161d1e1f222120565758595a
23097f07830100006a030c002000303e200000023a801871382d40582c4500ba
892100001ee97500a0a0a0295030203500ba892100001e023a80d072382d4010
2c4580ba892100001e011d007251d01e206e285500ba892100001e00000000f7
Feb 02 21:08:25 ELEC kernel: hdmitx: system: update physical size: 700 390
Feb 02 21:08:25 ELEC kernel: hdmitx: system: get current mode: 2560x1440p60hz
Feb 02 21:08:25 ELEC kernel: hdmitx: check failed vic: 793
Feb 02 21:08:25 ELEC kernel: hdmitx: hw: set audio
Feb 02 21:08:25 ELEC kernel: hdmitx: hw: hdmitx audio_param->channel_num = 1, hdev->aud_output_ch = 33
Feb 02 21:08:25 ELEC kernel: hdmitx: fs = 2, cd = 4, tmds_clk = 241500
Feb 02 21:08:25 ELEC kernel: hdmitx: hw: aud_n_para = 6272
Feb 02 21:08:25 ELEC kernel: hdmitx: hw: set channel status
Feb 02 21:08:25 ELEC kernel: hdmitx: hw: [0x10e3] = 0x1f
Feb 02 21:08:25 ELEC kernel: hdmitx: audio: Audio Type: PCM
Feb 02 21:08:25 ELEC kernel: [drm] drm hdmitx hpd notify
Feb 02 21:08:25 ELEC kernel: [drm] meson_hdmitx_hpd_cb[1993]
Feb 02 21:08:53 ELEC kernel: audio_ddr_mngr: frddr stop success, fifo id 0, regbase:0x70, arb sts:0x40000010
Feb 02 21:08:53 ELEC kernel: notify tdm to hdmitx,id 2 codec_type 0
Feb 02 21:08:53 ELEC kernel: iec_info: rate: 44100, codec_type:0x0, channel status L:0x100, R:0x100
Feb 02 21:08:53 ELEC kernel: hdmitx: hdmitx_notify_callback_a[6305] type:0 rate:44100 size:32 chs:2 fifo_rst:0 aud_src_if:1
@freddy not sure about other stuff… only had this running a few weeks, and this week finally decided to use nfo/jpg files on my NAS and scrape local info on Kodi. Grabbed Media Companion, and been slowly changing artwork and files etc. TV series finally done so scraped that to Kodi and while testing just kinda tried an episode of The Office, and kept going. :smiley: Only gonna watch a few seasons though, once Ed Helms joined the series it kinda went downhill for me.
Nightly.ng though means format SD card and start over? I have 20.3 now, the update didn’t work so had to manually download the file and apply it.
Start over
Yes and No
If you have a spare SD card or USB drive
Use that to test Nightly. ng
I have some spares from old cell phones
So have 3 version for HK1X4 Box
You can import library/media files etc
To test on different versions
@freddy I might have to buy a cheap test card to try with. Only SD cards I have are for the CoreElec boxes, and 1 for my 3D Printer.
Just clicked to power off, and again, signal tells my TV to shut down fine, but when I look, the blue light is still on my box. Give it 10min, and still on. Turn the TV on and sure enough, it’s stuck on the shutdown menu again.
That can be more of an HK1X4
CeC issue
Than CoreELEC version.
There is an old thread all about the HK1X4 S905X4
Its alot of reading
System will condense for you
You can skim over most posts
It would be most beneficial
Alot of these issues have already been discussed
@freddy bummer… wish I saw that before bought it. But, was a tight budget so, what can ya do. Went back to school and just finished a few weeks ago so, once working again I’ll probably grab an X96 S928X 8GB DDR4, or one of those Odroids look good… preferably something off the supported list. Shame Beelink doesn’t make the S905X-? based stuff anymore. Love that Beelink. Solid performer. Still have one working in the family room.
Hk1x4 still a decent box, once you gave it fine tuned/tweaked.
Nexux Nightly…ng is most stable currently
For my needs on this Box.
I switch back and forth between. ng and .no
Bypassed the .ne kernel
Regardless of TV Box iam using
I always disable CeC in CoreELEC
Main TV with multiple inputs kept waking up the HK1
Every time i changed inputs.
Just my own work around :relieved:
Happy Testing
Continue here: CoreELEC 20.4-Nexus Amlogic-ne Discussion
Closed!
