CoreELEC 20.3-Nexus Amlogic-ng Discussion
It’s recommended to use Amlogic-ne on SC2, S905X4 or above!
Yes, I started with ng , all the settings is already set
ne need fresh install right?
there is easy way to backup and restore?
Bluetooth does not work for me on 20.3-ng-dv
It works in the Ugoos OS, but stops working in CoreElec. Is anyone able to help? Even the default remote isn’t working in CoreElec. Bluetooth searches find the remote, but fails to connect with an error.
Any help besides resetting everything? Bluetooth won’t work connecting to any device/remote, but works perfectly in the Ugoos OS.
https://wiki.coreelec.org/coreelec:ce_addon_system
I noticed a weird issue after updating CE from 20.2 to 20.3.
Before there was a switch in the settings>coreelec>network to switch on/off wifi. This switch disappeared after the update. Now there is only the on/off switch for wired connections in the menu.
How can i fix this?
I am unable to switch wifi on or off at the moment.
We need more info.
Hi, when I update from CE 20.2 to 20.3 and try to play a video file, instead of just playing it, I get a popup with the following message: “No video Information available”. After downgrading to CE 20.2 everything works fine.
Is there a setting that I have to change after the Upgrade to 20.3 or could this be a bug?
Edit: My Device is the Odroid N2
Make as recommend a fresh install and try again!
20.4 just downloaded on mine but I cant see any posts on it?
Something with 20.3 is borked on my ODROID-N2
Wi-Fi only works momentarily, and then it disconnects and I am only able to reconnect by turning the wireless networks Active switch to off and then back on. It would reconnect to the wifi network, stay connected for a minute with internet access, and then disconnect. The State under Connections would say failure. I would not be able to connect to any other wifi network either, but they would show up in Connections.
Downgraded to 20.2, and Wifi connection is stable.
I just wanted a working device to watch my shows, so I wasn’t going to go through all the trouble shooting stuff and do a clean install at 1:00 am. Has anyone else had this issue?
Continue here:
Closed!
