Thanks for the reply - i understand what you are saying
but at the same time - i have had this box running on all CoreELEC stable releases since 2022 and its always come back from standby in circa 5seconds without any wifi issues
so why would it only be doing this now - and not before ?
is it worth trying nightlies?
or
is there some other fix i could try ? as the hardware is clearly capable of suspend / wake
to explain a little further - the reason its an issue for me is - i use the box many times a day and it takes 1-2 minutes to boot from shut down - vs 5 seconds of near instant from suspend - so it is a bit inconvenient. I don’t want to leave it and the screen on when not in use.
there was a 400+ post thread on this box alone - so i won’t be the only user with this issue
Why then? There is not much difference from Standby mode and "Settings → Interface → Screensaver → SS Mode → Dim => Settings => 1%. This completely turns off the screen in 1-60min wait time, and power consumption is marginally different between these two options.
Why not just adjust the CEC adapter settings to keep the device always on when you turn off your TV? It only uses a few watts when idle. It’s what I do, so it’s always ready to go when I turn on the TV.
WHICH box is that?
If it is X96 Air 4/32GB, it comes with a 5V 2A (that is 10W!) power adapter and it has “Power Consumption of 6W” !!!
For comparison, Ugoose AM6B+ comes with a original power adapter 12V 2A; that is 24 Wats!
Can’t you see that those numbers, 67W and 41W, are completely IMPOSIBLE to achieve with a 10W power adapter??? Same goes for your conclusion regarding power savings.
Also, if you are so concerned with power consumption during inactive state, you must in
CoreElec Settings → Hardware → Performance → CPU governor → set to “ondemand”; this way CPU can slow down to lowest frequency and power consumption during inactive states.
Yes, completely.
Not to try again to understand something so badly written, that it needs additional, and again not complete, explanation in a completely wrong thread.
Have a nice day and please save and conserve power as much as possible, no matter what method you use, since that will save our planet.
