CoreELEC 22.0-Piers_alpha1 Discussion
This fixed the problem I had since I try to launch NO.
Have 2GB rev.A unit.
Thanks!
Please try also these changes:
Enusre max_freq_cluster is disabled in config.ini before testing!
none is working.
v1 is bootlooping after a multicolor noisy background, and v2 is rebooting after a brief log of CPU errors.
And this version?
g12b_s922x_odroid_n2_v3.dtb (75.0 KB)
Doesn’t work either, it behaves like V1 with a different noise image, then it reboots.
edit: same v3 dtb with max_freq_cluster=‘0:1800,1:1896’ is booting fine
@doug @mattamore please set max_freq_cluster in config.ini and then update with this build:
like by SSH: update-ce https://…
After the update disable the max_freq_cluster in config.ini again and see if it does boot now.
Then please make a dmesg | paste.
update → ok
reboot → ok
`max_freq_cluster` disabled → ok
reboot → ok
dmesg : https://paste.coreelec.org/PinkyHoynes
My experience was simliar as mattamore’s.
v1. multi-coloured speckles and a freeze after HK logo
v2. HK logo, CE logo, bootloop
v3 HK logo, CE logo with many numbers down the screen and a kernel panic
your build on mega worked: https://paste.coreelec.org/MeeksMidge
can latest COREELEC 22 piers ALPHA1 supported Gt KING s922?
Yes, as was documented in original NO announcement (Piers is NO based).
Beelink GT King G12B S922X
use g12b_s922x_beelink_gt_king.dtb
Note that you, I suppose, come from 32 bit NG, but, NO is 64 bit.
So upgrade may have some issues for some add-ons that depend on binary 32 bit files.
This, of course, is not a CE upgrade issue but an add-on issue.
I personally did a clean NO install coming from NE.
I had a backup to easily reinstall some configuration files for some specific add-ons userdata if needed.
I am not sure if developers recommend clean install or also allow normal NE to NO upgrade.
thats a fair point, my only reason for keeping updated is to pick up the latest version of Kodi, although I must admit the current version is very stable and provides all I currently need
Guys thanks for your kind reply regarding gt king support. Can you verify that google addons (cguzzman repository 3.0 report.daro.mx) works in latest coreelec 22 piers alpha 1 because I only use Google addon (cguzzman repository 3.0 report.daro.mx) in coreelec.
I cannot tell if google addons (cguzzman repository 3.0 report.daro.mx) works.
I do not use them …
If they need binaries for which no working 64bit files exist, then too bad.
If not, and they would not be latest Python 3.13.x proof, then too bad.
But … many addons, certainly from decent developers, support 64bit and Python proof :slight_smile:
Bluetooth still not found in a95x f4 4gb, 128gb, 100mbit version but wifi is working now. But my 8 yr old bluetooth 4.0 dongle works now. We good. Everything else is a-ok
Thanks devs!
I think this is the wiser answer. I love DV and FEL on my ugoos and im terrified to be automatic updated into a version that doesnt support it anymore. I guess I will grab a install version and a recent update file to keep it stored in case that happens
Thanks for support, Work very well new alpha
I have tried to boot my Odroid N2+ from USB drive that I had prepared with both, rufus v4.9 under Win 11 and USBImager 1.0.10 under Ubuntu 24.04.3 LTS and in both cases the petitboot manager always fails to load it.
I had also tried with the g12b_s922x_odroid_n2.dtb from device tree folder an have put it into the root of the COREELEC partition, renamed to dtb.img - no success.
The Odroid simply doesn’t want to boot the 22.0-alpha 1, while the 21.2-stable boots ever since from my other USB drive.
Any hints? Thanks.
Why you copied dtb.img?
When using the N2 image the DTB is already in place. CE-NO does not support petitboot, so switch must be in eMMC position.
If still not working try to use uSD or eMMC.
