CoreELEC 22.0-Piers_alpha2 Discussion
Please use this thread for general CoreELEC 22.0-Piers_alpha2 discussion
Pardon my ignorance, but is a S905X4 device like Vontar X4 still supported for CE 22? Not sure if S905X covers that or not.
hello there, i ve changed from ce-ng 21.3 to ce-no (current nightly) - fresh install on the am6b+.
system running without problems, but i have problems with hibernate. when i turn off tv, system should turn to standby/hibernate. when i turn tv back on, system should be ready very fast, but screen stays black and after approx. 30 seconds, system is booting up normal. this behaviour was much better with ce-ng. is there a problem with the newer cec 7 driver?
I use simple client to watch iptv. The problem is with alpha2 on a TV channel. The system freezes and I have to disconnect the power to restart.
Yes ,have HK1X4 Vontar clone ,all is good
My 2 S905X4 (Tox3) both seems to be working ok. :slight_smile:
OK on wired, slooow on wireless but I use wired (eth) anyway.
Odroid N2+ 4gb ram.
Regarding the network. I wrote about it in the alpha1 topic. I was told that it could be caused by the lan cable. Now I have CAT.7 but nothing has changed. It still goes to a maximum of 100mb, despite the fact that the network card is 1gb.
You have a band width limitation somewhere on your network path. There is no user option to limit the speed in CE (at least not by professional hack).
Install Hardkernel Ubuntu on your device and you can recheck and compare.
nobody experienced similiar to that?
The nightly build of CoreELEC (no version) released on November 11 doesn’t support strm files generated from ISO, but supports those generated from MKV. Could you please fix this when you have time? I’m having the same issue with the Emby plugin.s905x4-j
Installed on my Tox3 2 days ago, so far all running fine, using ETH, openVFD works with the current conf, did not check the remote, but on the last 21.x builds I got the issue when playing 4k content that my menu whould be not scaled correctly and with 22 alpha everything seems cool, also able to play DV movies in HDR (previously it was purple/green).
Really love the Tox3 so far, it`s been great with CE.
WOW …8 pages of changes :slight_smile:
I wish I understood what all those lines of txt meant :frowning:
When will the STRM files generated for ISO be playable? Currently, tests have shown that the STRM files generated for MKV are supported for playback.
Follow Wiki:
https://kodi.wiki/view/Internet_video_and_audio_streams
If problems ask in Kodi forum.
OK,Thank you
Odroid N2+ 4g Ram
Does anyone have a problem with the Spectrum visualization? (black screen). The others work.
Does anyone have a problem with playing audio files with a frequency of 44.1 kHz? Intermittent playback.
I don’t have an N2 but after various issues I only use all the default screen and skin settings with other options turned off as required. Just makes thing work better in my case.
Model: Tanix TX5 Plus (32/4) (s905x5m).
with s7d_s905x5m_4g_1gbit.dtb.
Problem:
1 - instead of shutting down, it reboots
2 - no wi-fi, no bt (reported in the relevant thread)
3 - freezing when VC-1 decode.
4 - artifact on software decode mpeg-4
