Please use this thread for general CoreELEC 22.0-Piers_alpha3 discussion
Just one quick question! Am I correct that in the case of CoreELEC 22.0-Piers on the Ugoos AM6B+, Dolby Vision FEL playback is no longer supported?
Really? Need to ask again and again?
No, no FEL with CE-22 NO build.
I want to try get analog audio working on an agreed somewhat old Ugoos X3 Pro so I do
$ git clone GitHub - CoreELEC/CoreELEC: A lightweight OS for KODI · GitHub
$ cd CoreELEC/
$ git checkout -b 22.0-Piers_alpha3 22.0-Piers_alpha3
$ scripts/build linux
That goes fine and I get sm1_s905x3_4g_1gbit.dtb …
Now I change sm1_s905x3_4g_1gbit.dts but if I next do
again, … nothing happens.
sm1_s905x3_4g_1gbit.dtb does not get rebuilt.
Question : How do I manage to do so i.e. to just rebuild the dtb?
fwiw: the change is
auge_sound { avout_mute-gpios = <&gpio GPIOD_2 GPIO_ACTIVE_HIGH>; aml-audio-card,dai-link@1 { codec { sound-dai = <&amlogic_codec>; }; }; };
which may not fit other s905x3 but may fit my (agreed unsupported) Ugoos X3 Pro
Note that this device is not any of my daily players. I am only experimenting.
Thanks in advance
If all you are working with is device trees then just use device tree compiler
dtc -I dts -O dtb -o sm1_s905x3_4g_1gbit.dtb sm1_s905x3_4g_1gbit.dts
Full how to here: How to use the command 'dtc' (with examples)
Linux package (debian) device-tree-compiler
and IIRC this is included in CE so you could use SSH on a CE box if so.
@neqwdtkukwjaanti thanks for reply
I had tried device tree compiler but maybe not exactly correct command line usage… ![]()
I got a compile error line#1 (both on original and new dts)
So I then thought perhaps some target for
$ scripts/build target # rebuild dtbs
existed.
I am now restarting entire linux build from scratch and will try dtc again. Keep you informed.
Have a nice day
update
here error on original dts
$ dtc -I dts -O dtb -o sm1_s905x3_4g_1gbit.dtb sm1_s905x3_4g_1gbit.dts
Error: sm1_s905x3_4g_1gbit.dts:1.1-2 syntax error
FATAL ERROR: Unable to parse input tree
I also tried -i option
$ dtc -i . -I dts -O dtb -o sm1_s905x3_4g_1gbit.dtb sm1_s905x3_4g_1gbit.dts
After you have made your edit run
rm -f build.CoreELEC-Amlogic-no.aarch64-22/.stamps/linux/build_target
then
scripts/build linux
removing the stamps forces a rebuild with the current local files.
I don’t know what your entire dts edit looks like to know why dtc is failing.
I think I see why, I made an assumption they had a full dts they were working with.
Instead the only place it exists is from the linux source (on my end)
- build.CoreELEC-Amlogic-no.aarch64-22/build/common_drivers-a687c1bf3c0ea926b6b722fcebb62dd110115eea/arch/arm64/boot/dts/amlogic/sm1_s905x3_4g_1gbit.dts
Those are not working with dtc
this works! Thanks
fwiw: Unfortunately I could not get analog audio to work and the Ugoos X3 bluetooth does not work either. In fact, the patch was a noop since amlogic_codec is set in coreelec_sm1_common.dtsi …
fair enough … it is not as supported box anyway
