CoreELEC 22.0-Piers_alpha3 Discussion
What are you even talking about? I haven’t asked anything on this forum for about a year and a half. :slightly_smiling_face: I’d suggest you take a little break sometimes too… :wink:
I’m talking about that you should read a forum a little before posting such question. Because your question was answered 100 times. Ok, now 101 times.
Hi, I am using a generic S905X3 device. The new alpha3 version runs well overall.
But I have issues with DVD ISO playback and navigation.
When I use the hardware MPEG2 decoder DVD menus do not work properly or do not open at all.
Switching to software decoding brings back working DVD navigation, BUT: MPEG2 videos start to stutter like hell.
This does not happen on the Omega stable release. Playback and scaling of the video to HD work smooth.
I am pretty sure that the scaler in Piers version has issues, because
when I set the picture size to “Original” all runs smooth (but picture
on the TV is too small of course).
I have seen some older posts about DVD playback issues on newer
CoreELEC releases triggered by the new feature “hardware decoded DVD
menus”.
Is this issue known and are there possible fixes for it?
Today I updated to Πers nightly (20260314) :smile: Everything works exactly as it worked with 20260224 I was previously using.
Only 2 things to report, which both haven’t worked for a bunch of months now but they’re not critical.
  1. I often download some videos from YouTube especially from The HDR Dissector aka RESET_99, don’t know if he’s still present and active on this forum. I download the videos with the following command: yt-dlp –merge-output mkv -f 251+337 and I can’t get these videos to trigger the HDR mode anymore for several months. The latest video - https://www.youtube.com/watch?v=ubf3b0SlxIc - is no exception. mediainfo does not show any HDR flag. The command yt-dlp -F https://www.youtube.com/watch?v=ubf3b0SlxIc confirms that 337 is 2160p HDR.
    The last videos I can remember that worked as expected were from october/november 2025, respectively - https://www.youtube.com/watch?v=epgZkw1Vd5I and https://www.youtube.com/watch?v=AuPXcBkKxtg . Anything newer like https://www.youtube.com/watch?v=iMJnw_VHZIw don’t trigger HDR mode anymore once downloaded.
  2. If I set Kodi -> System -> System -> Display -> Delay after change of refresh rate to anything above 0.4s, this is what happens:
    • Most videos end up in a black screen
    • Some videos, especially HDR ones, display the first frame frozen. I must press Pause twice (triggers pause and then play) to start the video.
    Up to CE-NO 20250624 it worked perfectly and the first release I faced the problem was 20250407.
I only report these in case there’s something to do about it. The first issue is a bit annoying as “The HDR Dissector” produces really nice and informative comparison videos. The second one I can live with it.
Just curious: which exact box, and, you play sound via which device:
(PCM | S/PDIF | Bluetooth | …)?
I also have an X96 S905x3 that I occasionally use. I play all sound from an AVR (AMP) through the hdmi to 5.1 speakers.
OK … thanks. I very occasionally use Ugoos X3 Pro S905x3 and HDMI sound output does work as well. Have a nice day!
I am using a Chinese HK1 box. And the audio goes via HDMI Passthrough to the AMP device.
Hi there.
I also had a delayed set in previous alpha 2 and I had the same issue: blank screen/first frame stopped on screen. I had to press pause and play again to resume it.
I solved it by removing that setting. In practice, it works: the new resolution is set in my Sony TV and the video is played. I do not notice any issue or artifact by doing this…
I did not find here anybody else with this problem, so I guess it is Kodi’s. But it would be nice to know it and actually solve it.
Hi, I have a GT-King 922x device and have Wi-Fi problems for a few weeks. After starting up, the Wi-Fi connection drops. When I reconnect, it stays active. There’s no problem with the wired connection. Does anyone know a solution?
@kengithub9 Strange
I also have a GT-King 922x but I have no Wi-Fi at all. I run nightly NO images and ssh login shows
CoreELEC (official): 22.0-Piers_nightly_20260321 (Amlogic-no.aarch64)
Machine model: Beelink
CoreELEC dt-id: g12b_s922x_beelink_gt_king_rev_a
Amlogic dt-id: g12b_w400_a
Linux version: 5.15.196 (docker@173d49f57196) #1 Sat Mar 21 01:29:10 IST 2026
Kodi compiled: 2026-03-21 01:41:57 +0100
I use g12b_s922x_beelink_gt_king.dtb (md5sum b4b90595d5fec302a5de21259f587401)
Does your system show deviating information (like maybe another rev)?
My system is the same as yours i think, where can i see these information?
It looks like CoreELEC has these values in /proc/device-tree which is a symbolic link to /sys/firmware/devicetree/base
Here some values you can find via ssh to the box
I append the ‘ && echo’ since these files don’t have a trailing newline
Note that wifi/status says okay but WiFi is not available
GT-King:/sys/firmware/devicetree/base # cat amlogic-dt-id && echo
g12b_w400_a
GT-King:/sys/firmware/devicetree/base # cat compatible && echo
amlogic, g12b
GT-King:/sys/firmware/devicetree/base # cat coreelec-dt-id && echo
GT-King:/sys/firmware/devicetree/base # cat model && echo
Beelink
GT-King:/sys/firmware/devicetree/base # cat wifi/compatible && echo
amlogic, aml-wifi
GT-King:/sys/firmware/devicetree/base # cat wifi/name && echo
wifi
GT-King:/sys/firmware/devicetree/base # cat wifi/status && echo
okay
amlogic, aml-wifi
while on topic bt-dev/status says okay but Bluetooth is not available
GT-King:/sys/firmware/devicetree/base # cat ./bt-dev/compatible && echo
amlogic, aml-bt
GT-King:/sys/firmware/devicetree/base # cat ./bt-dev/status && echo
okay
GT-King:/sys/firmware/devicetree/base # cat ./bt-dev/name && echo
bt-dev
/proc/device-tree is a read-only pseudo-filesystem directory that exposes the Device Tree as it was parsed and used by the running kernel.
It just shows the values in DTB.
Hi there.
I also removed it for it to work properly but I’m not satisfied. When playing a video, the sound plays immediately but the screen is still black because the whole HDMI chain is a bit slow to react and properly sync/detect the signals. DuneHD Box R 4K → Denon AVR → OLED TV
This is especially noticeable when switching from Kodi interface (1080p SDR) to 4K HDR (no matter if plain HDR, DolbyVision, HDR10+ or HLG). Some videos have immediate content without “introduction/credits” screens (ie: “Previously on …” for TV shows) and some visual content is lost.
Up until CE-NO 20250624, any delay would work without issue. I suppose that the real problem is in Kodi with some kind of race condition somewhere.
Hi everyone. I have a Dune Pro Vision 4K box. I decided to upgrade from the 21-NE to the 22-NO to solve AV1 playback issues. The 22-NO hasn’t had any issues so far, except for one. I’m using a pseudo-sleep script (turning on the red LED instead of the blue one and disabling the video output). It works on both the NE and NO. However, in NO, it consumes 105% of CPU (waiting for the ‘value 408’ IR signal) and runs slightly hotter than when playing FHD video, even just with the main screen on. “CoreELEC:~ # top” also shows the R status instead of the S on the 21-NE, for kodi.bin process. In 21-NE it consumes about 6% of the CPU. Here’s the script itself; it works perfectly with the included R4 remote control:
#!/bin/sh
sleep 1
/usr/bin/kodi-send --host=127.0.0.1 --action=“PlayerControl(Stop)”
pkill -f “evtest /dev/input/by-path/platform-fe084040.meson-ir-event”
/usr/bin/systemctl stop eventlircd
kodi-send --action=“InhibitScreensaver(true)”
echo 0 > /sys/class/amhdmitx/amhdmitx0/phy
echo 0 > /sys/class/leds/sys_led/brightness
(/storage/.kodi/addons/virtual.system-tools/bin/evtest /dev/input/by-path/platform-fe084040.meson-ir-event &) | grep -m 1 ‘value 408’
echo 1 > /sys/class/leds/sys_led/brightness
echo 1 > /sys/class/amhdmitx/amhdmitx0/phy
kodi-send --action=“InhibitScreensaver(false)”
/usr/bin/systemctl start eventlircd
How to reduce CPU consumption?
Sorry for text. Unable to paste media here for some reason, maybe because I’ve just registered.
Tasks: 184 total, 2 running, 182 sleep, 0 d-sleep, 0 stopped, 0 zombie
%Cpu(s): 24.6 us,  1.8 sy,  0.4 ni, 72.4 id,  0.0 wa,  0.7 hi,  0.1 si,  0.0 st
MiB Mem :   3661.1 total,   1607.1 free,    907.6 used,   1234.3 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2753.5 avail Mem
PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
1359 root      20   0 3206640 425064 115096 R 104.5  11.3  34:21.35 kodi.bin
1470 root      20   0 9666436 114244  24856 S   0.7   3.0   0:41.80 python
2414 root      20   0    7188   4040   1896 R   0.7   0.1   0:00.43 top
15 root      20   0       0      0      0 I   0.3   0.0   0:00.41 rcu_preempt
556 root      20   0   86532    276    228 S   0.3   0.0   0:07.55 OpenVFDService
663 root      -2   0       0      0      0 S   0.3   0.0   0:08.00 ksdioirqd/mmc2
Maybe kodi goes crazy because you stopped eventlircd and doesn’t have input anymore?
Try suspend and resume kodi process? Something like that
kodi-send --action="PlayerControl(Stop)"
kodi-send --action="InhibitScreensaver(true)"
pkill -STOP kodi.bin
pkill -CONT kodi.bin
kodi-send --action="InhibitScreensaver(false)"
Thanks for the reply. I’m stopping eventlircd to listen for events on platform-fe084040.meson-ir-event, otherwise it’s blocked. I’ve previously tried pkill -STOP and pkill -CONT, but stopping/starting eventlircd prevents Kodi from waking up, even with a separate command via SSH, Kodi stays freezes in forever. It seems there’s a glitch that can only be fixed with a restart.
UPD! This was the case in 21-NE. No matter how much I tried, Kodi always crashed after a few cycles. But in 22-NO, it seems that pkill -STOP, pkill -CONT combined with stopping and starting eventlircd no longer cause a Kodi crash! Thank you again.
I was watching a two-hour movie with a video bitrate of 78.6 Mbps and about once every 20-30 minutes there was buffering for about 5 seconds.
CoreELEC:~ # smbclient “``//192.168.1.1/Keenetic`` SSD” -N -c “get Hamnet.2025.BDRemux.2160p.HDR-DV.mkv -” | dd of=/dev/null bs=1M count=50000
0+50000 records in
0+50000 records out
3276800000 bytes (3.1GB) copied, 263.403484 seconds, 11.9MB/s
It’s WiFi, but it’s stable; there were no other devices connected during playback. I have a Dune HD Pro Vision 4K (S905X4-J), and the read speed is around 20 MB/s in DuneOS. I tried buffer sizes from 128 to 512 MB, and the problem persisted each time. It’s very strange, considering even such a low speed (~11.9 MB/s) should be sufficient for this movie, especially with such a huge buffer. Why is the Coreelec’s speed so much lower?
I changed the chunk size to 1 MB for SMB, otherwise there would be a slideshow. The highest temperature I saw during playback was 44 degrees.
I regret to tell you that your test is invalid.
Does not take into account overhead of WiFi and CPU usage.
Does not take into account variable bitrates of video, even if the average video bitrate is 78.6 that doesn’t account for video bitrate spikes.
Doesn’t account for 20-30 minutes of video playback or the ram usage associated with it.
I can tell you though that 95Mbps is not enough for smooth 4K playback even if that’s what you actually got during the entire playback.
I can also tell you 95Mbps is rather slow even for WiFi.
