No.
I can’t explain it, my suggestion would be to try an earlier build, but I don’t know where to get them.
I’ve moved back to using autostart.sh to force 444 10 bit again temporarily and everything is working ok for now.
@Duke you seem to be using the nightly build. The auto bit depth and auto color space switching code was removed from the nightly builds until it was working better. Which is why everything was staying 8bit.
If you want to try the auto bit depth switching code you need to use 8.95.4.42 which is the latest test release that contains that feature.
OK, sorry for the confusion, I’ll give that test build a try
Was an auto update of this latest version pushed?
