Works fine, you can pause/resume at any time. Mainstream version requests another session upon resuming, you can hear sound sync every time.
As routir said, there’s no issue, but since the implementation we have here is sort of a hack, it does not renew the session on resume. So if your session has timed out, you’ll be at the mercy of your iptv provider’s server behavior in regards to expired sessions.
But I am still able to pause/resume with old version of your addon, before mainstream stuff backported. Server is the same in both cases. What is different then? Does old implementation make request for another session after resume? You can’t assume provider is not going to invalidate session when you stop playback.
I have not test mainstream with that server though
Nothing changed from that perspective. I don’t know why it’s working differently for you.
What version exactly?
Let me test and say if it’s working in my case.
Latest stable version. But Flussonic is not supported by default, need to convert playlist first to set catchup pattern for each channel.
I am sure I am able to pause/resume without any problems. Maybe some logs could clarify that?
As I said, nothing changed in the way media is handled. The only thing that’s different is how the url is converted into usable archive url.
Not working.
My platlist contains catchup=“default” catchup-days=“7” catchup-source=
As well as catchup-days=“7” catchup-type=“flussonic”
In the upstream version I set All channels support catchup using mode to disabled to make it work.
Maybe we should ask phunkyfish about the pause/play mechanism and implement similar feature into CoreELEC if possible.
Just got the answer from phunkyfish:
came back to update that XC works just fine here.
the “Play Programme” on EPG item select is not available on some skins (probably all except Estuary), but it can be found on (most) skins on the context menu.
I tested it here and it works fine, including skipping (which I previously thought wasn’t working) and pause/resume, on version 3.9.8.3.
(there’s an inconsistency between the content played and the EPG item, but I think it’s my providers fault.)
so thanks a lot for all of your hard work @TheCoolest.
It won’t work, you need to convert playlist as mentioned earlier in this thread. Flussonic is not supported.
I know about the mono-{start}-3600 syntax, but that does not allow to go forward/rewind. Pause/resume works fine.
I am able to seek without any problems. CoreElec latest stable and pvrviptv archive from repo, Flussonic server
Anybody succeded with shift (siptv) protocol? Either this experimental build or mainstream iptv simple addon on nightly. In my case it always shows all channels have no archive when I load playlist and set archive type to siptv. No green dot and no archive.
Hi.
I have a list with these settings for the archive
catchup-days=“5” catchup=“fs” catchup-source="?utc={utc}&lutc={lutc}"
(for this playlist i use " All channels support catchup using mode “Default” "
(this playlist has a token at the end)
which works in kodi 19 on android and windows
however it does not work on coreelec
"I tried masses of different configurations, there are almost always tags that the archive is available but it doesn’t work."
my 2nd list has similar settings and works fine on windows, android and coreelec
catchup-days=“3” catchup=“append” catchup-source="?utc={utc}&lutc={lutc}"
(for this playlist i use " All channels support catchup using mode “Append” "
(this playlist has a .m3u8 at the end)
whether it’s a list problem? or an addon or inputstream in coreelec?
thanks for any help…
I will need to check, but I think the current logic ignores catchup-source if catchup is provided.
Perhaps it needs to be the other way around.
buddy, hold on, i found an addon a few posts above which seems to work fine.
I’ll just check the list that works on the older version of the addon but it seems to be ok.
my entry on the m3u list
catchup-days=“5” catchup-type=“default” catchup-source=“?utc=${start}&lutc=${timestamp}”
and “Flussonic” on addon settings
thank you !!!
hello Guys.
I have problem and i don’t know why. I have CE 9.2.4.2 and latest version PVR IPTV Archive client.
Archive working but I cannot rewind or rewind while viewing archived material and can’t pause/play when watch tv.
I’ve plusxtv list.
Please help me! i heven’t idea what’s is wrong.
which one? old or new?
