sorry, I have to rethink and open a new thread if necessary.
Hopefully the HDR10+ issue will be looked st soon. At least it doesn’t affect a lot of titles yet
I’ve reactivated an S912 box from retirement…
Does anybody else besides ragico actually have a HDR10+ capable TV here?
@ragico Can I get you to run the dispinfo script, and post the url it spits out, so that I have some debug info about your TV. Pretty much want to check that the HDR10+ capability of the display is being detected correctly.
Yes I can run the dispinfo script, but dont know yet how to do it.
My display only support HDR10 & Dolby Vision. Happy to do anything to try and get HDR10+ working. If needed too I’ll try and find a HDR10+ display.
But if you need anything, happy to help
@ragico, as usual via ssh while watching HDR10+ video
dispinfo and press enter
You will receive a link. Add this link in answer.
This is the link:
http://ix.io/1PkB
thank you. you’re always helpful
I’ve done some testing and I think that for further testing we should use samples that are verified to be correct in order to trigger HDR10+. So, making a database of HDR10+ samples should be considered. When testing a sample with CoreELEC, it should also be tested with the TV’s internal player to see any differences and if the sample is triggering HDR10+. The problem with HDR10+ is that if the file is not recognized as HDR10+, it will fallback to HDR10. This makes it even harder to figure this out without proper equipment to read signal received etc like an AVR or a TV which show detailed information.
Internal player - Samsung QE55Q6FNA
With Samsung internal player, sample 2-4 triggered HDR logo (I don’t know if there is a HDR10+ logo, so can’t tell if I actually got HDR10+).
Android - VIM3 Pie V190704 (4.9.113)
With Android (VIM3 Pie V190704) all samples showed HDR logo (still no HDR10+). I tried both Amlogic Player and OMX).
CoreELEC
Display info before playback
CoreELEC Display Information...
------------ /etc/os-release ------------
NAME="CoreELEC"
VERSION="nightly_20190722"
ID="coreelec"
VERSION_ID="9.1"
PRETTY_NAME="CoreELEC (official): nightly_20190722"
HOME_URL="https://coreelec.org"
BUG_REPORT_URL="https://github.com/CoreELEC/CoreELEC"
BUILD_ID="36eedaced3993afe5e8b3256e9117d2a5ec02d9e"
OPENELEC_ARCH="Amlogic-ng.arm"
LIBREELEC_ARCH="Amlogic-ng.arm"
COREELEC_ARCH="Amlogic-ng.arm"
COREELEC_BUILD="official"
COREELEC_PROJECT="Amlogic-ng"
BUILDER_NAME="relkai"
BUILDER_VERSION="nightly_20190722"
------------ /proc/device-tree/coreelec-dt-id ------------
g12b_a311d_khadas_vim3
------------ /proc/device-tree/le-dt-id ------------ Missing!
------------ /proc/cmdline ------------
init=/init console=ttyS0,115200 no_console_suspend earlycon=aml-uart,0xff803000 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 rootfstype=ramfs otg_device=1 reboot_mode_android=normal logo=osd0,loaded,0x3d800000 vout=576cvbs,enable panel_type=lcd_1 hdmitx=,444,12bit hdmimode=1080p60hz frac_rate_policy=1 hdmi_read_edid=1 cvbsmode=576cvbs osd_reverse=0 video_reverse=0 irq_check_en=0 androidboot.selinux=permissive androidboot.firstboot=0 jtag=disable androidboot.hardware=amlogic androidboot.serialno=REMOVED mac=REMOVED androidboot.mac=REMOVED wol_enable=0 bootfromsd console=tty0 systemd.show_status=auto BOOT_IMAGE=kernel.img boot=LABEL=COREELEC disk=LABEL=STORAGE
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/edid ------------
Rx Manufacturer Name: SAM
Rx Product Code: 0f0b
Rx Serial Number: 01000e00
Rx Product Name: SAMSUNG
Manufacture Week: 1
Manufacture Year: 2018
Physcial size(cm): 121 x 68
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0xe5
Source Physical Address[a.b.c.d]: 1.0.0.0
native Mode f0, VIC (native 255):
ColorDeepSupport b8
97 16 31 4 19 5 20 32 33 34 93 94 95 96 101 102 98 99 100 7 22 3 18 63 64 95 94 93 98 353 352 357 358
Audio {format, channel, freq, cce}
{1, 1, 7, 7}
{2, 5, 7, 50}
{10, 7, 7, 1}
Speaker Allocation: 1
Vendor: 0xc03 ( HDMI device)
MaxTMDSClock1 300 MHz
Vendor2: 0xc45dd8
MaxTMDSClock2 600 MHz
ALLM: 1
vLatency: Invalid/Unknown
aLatency: Invalid/Unknown
i_vLatency: Invalid/Unknown
i_aLatency: Invalid/Unknown
ColorMetry: 0xc3
SCDC: 1
RR_Cap: 0
LTE_340M_Scramble: 0
HDR DeepColor
checkvalue: 0xe5930000
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/edid_parsing ------------
ok
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/rawedid ------------
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
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/config ------------
cur_VIC: 16
cur_video_param->VIC=16
VIC: 16 1920x1080p60hz
Colour depth: 10-bit
Colourspace: YUV444
Colour range: default
EOTF: SDR
YCC colour range: limited
Colourimetry: BT.709
PLL clock: 0xdb14049a, Vid clock div 0x000b0000
audio config: on
audio on/off: on
audio source: SPDIF
audio type: L-PCM
audio channel num: 2 channels
audio sample rate: 44.1kHz
audio sample size: 16bit
3D config: off
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/dc_cap ------------
420,12bit
420,10bit
420,8bit
444,12bit
444,10bit
444,8bit
422,12bit
422,10bit
422,8bit
rgb,12bit
rgb,10bit
rgb,8bit
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/attr ------------
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/disp_cap ------------
480i60hz
576i50hz
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz
smpte60hz
2160p50hz
2160p60hz
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/preferred_mode ------------
2160p60hz
------------ /sys/devices/virtual/amhdmitx/amhdmitx0/hdr_cap ------------
HDR Static Metadata:
Supported EOTF:
Traditional SDR: 1
Traditional HDR: 0
SMPTE ST 2084: 1
Hybrif Log-Gamma: 1
Supported SMD type1: 1
Luminance Data
Max: 0
Avg: 0
Min: 0
HDR Dynamic Metadata:
colorimetry_data: c3
------------ /sys/module/am_vecm/parameters/hdr_mode ------------
2
------------ /sys/module/am_vecm/parameters/sdr_mode ------------
0
------------ /sys/class/display/vinfo ------------
current vinfo:
mode: 0
width: 1920
height: 1080
field_height: 1080
aspect_ratio_num: 16
aspect_ratio_den: 9
sync_duration_num: 60
sync_duration_den: 1
screen_real_width: 1210
screen_real_height: 680
htotal: 2200
vtotal: 1125
fr_adj_type: 4
video_clk: 148500000
viu_color_fmt: 2
viu_mux: 2
3d_info: 0
master_display_info:
present_flag 0
features 0x0
primaries 0x0, 0x0
0x0, 0x0
0x0, 0x0
white_point 0x0, 0x0
luminance 0, 0
hdr_static_info:
hdr_support 13
lumi_max 0
lumi_avg 0
lumi_min 0
hdr_dynamic_info:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
hdr10+:
ieeeoui: 90848b
application_version: 1
------------ kodi display settings ------------
coreelec.amlogic.limit8bit:
coreelec.amlogic.force422:
coreelec.amlogic.deinterlacing:
coreelec.amlogic.noisereduction:
coreelec.amlogic.hdr2sdr: 2
coreelec.amlogic.sdr2hdr: 0
videoplayer.adjustrefreshrate: 2
videoplayer.useamcodec: true
videoplayer.useamcodech264: 0
videoplayer.useamcodecmpeg2: 0
videoplayer.useamcodecmpeg4: 800
videoplayer.usedisplayasclock: false
videoscreen.whitelist:
lookandfeel.skin: skin.estuary
------------ /storage/.kodi/userdata/disp_cap ------------ Unset by user!
------------ /flash/boot.ini ------------ Missing!
------------ /flash/config.ini ------------ Missing!
------------ /storage/.config/autostart.sh ------------ Unset by user!
Sample I - HDR10+DV.m2ts
Dispinfo - HDR10+DV.m2ts
Manufacture Week: 1
EDID Version: 1.3
blk0 chksum: 0xe5
ColorDeepSupport b8
{1, 1, 7, 7}
{2, 5, 7, 50}
{10, 7, 7, 1}
Vendor2: 0xc45dd8
ALLM: 1
ColorMetry: 0xc3
SCDC: 1
RR_Cap: 0
HDR DeepColor
ok
cur_VIC: 93
cur_video_param->VIC=93
VIC: 93 3840x2160p24hz
Colourspace: YUV444
EOTF: SDR
Colourimetry: BT.2020nc
PLL clock: 0xdb00049a, Vid clock div 0x000b0000
audio config: on
audio on/off: on
audio source: SPDIF
audio type: L-PCM
audio sample rate: 48kHz
3D config: off
420,12bit
420,10bit
420,8bit
444,12bit
444,10bit
444,8bit
422,12bit
422,10bit
422,8bit
rgb,12bit
rgb,10bit
rgb,8bit
480i60hz
576i50hz
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz
smpte60hz
2160p50hz
2160p60hz
2160p60hz
Supported EOTF:
Traditional SDR: 1
Traditional HDR: 0
SMPTE ST 2084: 1
Hybrif Log-Gamma: 1
Luminance Data
Max: 0
Avg: 0
Min: 0
2
0
current vinfo:
mode: 0
width: 3840
height: 2160
field_height: 2160
aspect_ratio_den: 9
sync_duration_num: 2997
sync_duration_den: 125
htotal: 5500
vtotal: 2250
fr_adj_type: 4
video_clk: 297000000
viu_color_fmt: 2
viu_mux: 2
3d_info: 0
present_flag 0
features 0x0
primaries 0x0, 0x0
0x0, 0x0
0x0, 0x0
luminance 0, 0
hdr_static_info:
hdr_support 13
lumi_max 0
lumi_avg 0
lumi_min 0
hdr_dynamic_info:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
hdr10+:
ieeeoui: 90848b
Mediainfo - HDR10+DV.m2ts
General
Complete name HDR10+DV.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 182 MiB
Duration : 36s 584ms
Overall bit rate mode : Variable
Overall bit rate : 41.8 Mbps
Maximum Overall bit rate : 109 Mbps
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID : 36
Duration : 35s 952ms
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 233 cd/m2
Maximum Frame-Average Light Level : 63 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Duration : 35s 953ms
Bit rate mode : Variable
Bit rate : 640 Kbps
Maximum bit rate : 5 013 Kbps
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 2.74 MiB (2%)
Service kind : Complete Main
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 917ms
The first sample actually bugged the GUI to move half a screen size up which resulted in the bottom half of the GUI showing on the upper half of the screen. A reboot fixed this.
Sample II - Alita- encSample.mkv
Dispinfo - Alita- encSample.mkv
Manufacture Week: 1
EDID Version: 1.3
blk0 chksum: 0xe5
ColorDeepSupport b8
{1, 1, 7, 7}
{2, 5, 7, 50}
{10, 7, 7, 1}
Vendor2: 0xc45dd8
ALLM: 1
ColorMetry: 0xc3
SCDC: 1
RR_Cap: 0
HDR DeepColor
ok
cur_VIC: 93
Colourspace: YUV444
EOTF: HDR10
audio config: on
audio on/off: on
audio source: SPDIF
audio type: L-PCM
3D config: off
420,12bit
420,10bit
420,8bit
444,12bit
444,10bit
444,8bit
422,12bit
422,10bit
422,8bit
rgb,12bit
rgb,10bit
rgb,8bit
480i60hz
576i50hz
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz
smpte60hz
2160p50hz
2160p60hz
2160p60hz
Supported EOTF:
Traditional SDR: 1
Traditional HDR: 0
SMPTE ST 2084: 1
Hybrif Log-Gamma: 1
Luminance Data
Max: 0
Avg: 0
Min: 0
2
0
current vinfo:
mode: 0
width: 3840
height: 2160
field_height: 2160
aspect_ratio_den: 9
htotal: 5500
vtotal: 2250
fr_adj_type: 4
viu_color_fmt: 2
viu_mux: 2
3d_info: 0
present_flag 0
features 0x0
primaries 0x0, 0x0
0x0, 0x0
0x0, 0x0
luminance 0, 0
hdr_static_info:
hdr_support 13
lumi_max 0
lumi_avg 0
lumi_min 0
hdr_dynamic_info:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
hdr10+:
ieeeoui: 90848b
Mediainfo - Alita- encSample.mkv
General
Unique ID : 55939360727858114587291192547757611875 (0x2A15876BDC36748C9D3A830EB9E15B63)
Complete name Alita- encSample.mkv
Format : Matroska
Format version : Version 4
File size : 169 MiB
Duration : 39s 331ms
Overall bit rate : 36.0 Mbps
Movie name : Alita: Battle Angel
Encoded date : UTC 2019-07-23 19:00:46
Writing application : mkvmerge v35.0.0 ('All The Love In The World') 64-bit
Writing library : libebml v1.3.9 + libmatroska v1.5.2
Cover : Yes
Attachments : cover.jpg
Video
Format : HEVC
Format profile : Main 10@L5@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 36.0 Mbps
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.181
Stream size : 169 MiB (100%)
Default : Yes
Forced : No
Maximum Content Light Level : 737 cd/m2
Maximum Frame-Average Light Level : 130 cd/m2
Sample III - Alita- sample.mkv
Dispinfo - Alita- sample.mkv
Manufacture Week: 1
EDID Version: 1.3
blk0 chksum: 0xe5
ColorDeepSupport b8
{1, 1, 7, 7}
{2, 5, 7, 50}
{10, 7, 7, 1}
Vendor2: 0xc45dd8
ALLM: 1
ColorMetry: 0xc3
SCDC: 1
RR_Cap: 0
HDR DeepColor
ok
cur_VIC: 93
Colourspace: YUV444
EOTF: SDR
audio config: on
audio on/off: on
audio source: SPDIF
audio type: L-PCM
3D config: off
420,12bit
420,10bit
420,8bit
444,12bit
444,10bit
444,8bit
422,12bit
422,10bit
422,8bit
rgb,12bit
rgb,10bit
rgb,8bit
480i60hz
576i50hz
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz
smpte60hz
2160p50hz
2160p60hz
2160p60hz
Supported EOTF:
Traditional SDR: 1
Traditional HDR: 0
SMPTE ST 2084: 1
Hybrif Log-Gamma: 1
Luminance Data
Max: 0
Avg: 0
Min: 0
2
0
current vinfo:
mode: 0
width: 3840
height: 2160
field_height: 2160
aspect_ratio_den: 9
htotal: 5500
vtotal: 2250
fr_adj_type: 4
viu_color_fmt: 2
viu_mux: 2
3d_info: 0
present_flag 0
features 0x0
primaries 0x0, 0x0
0x0, 0x0
0x0, 0x0
luminance 0, 0
hdr_static_info:
hdr_support 13
lumi_max 0
lumi_avg 0
lumi_min 0
hdr_dynamic_info:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
hdr10+:
ieeeoui: 90848b
Mediainfo - Alita- sample.mkv
General
Unique ID : 16715378685507121859825383458067551739 (0xC9343CC2CE59A857DAE08A1D6C595FB)
Complete name Alita- sample.mkv
Format : Matroska
File size : 205 MiB
Overall bit rate : 43.7 Mbps
Encoded date : UTC 2019-07-23 19:00:12
Cover : Yes
Video
Format : HEVC
Bit rate : 43.7 Mbps
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.220
Stream size : 205 MiB (100%)
Language : English
Default : No
Forced : No
Sample IV - Alita- x265sample.mkv
Dispinfo - Alita- x265sample.mkv
Manufacture Week: 1
EDID Version: 1.3
blk0 chksum: 0xe5
ColorDeepSupport b8
{1, 1, 7, 7}
{2, 5, 7, 50}
{10, 7, 7, 1}
Vendor2: 0xc45dd8
ALLM: 1
ColorMetry: 0xc3
SCDC: 1
RR_Cap: 0
HDR DeepColor
ok
cur_VIC: 93
Colourspace: YUV444
EOTF: SDR
audio config: on
audio on/off: on
audio source: SPDIF
audio type: L-PCM
3D config: off
420,12bit
420,10bit
420,8bit
444,12bit
444,10bit
444,8bit
422,12bit
422,10bit
422,8bit
rgb,12bit
rgb,10bit
rgb,8bit
480i60hz
576i50hz
480p60hz
576p50hz
720p60hz
1080i60hz
1080p60hz
720p50hz
1080i50hz
1080p30hz
1080p50hz
1080p25hz
1080p24hz
2160p30hz
2160p25hz
2160p24hz
smpte24hz
smpte25hz
smpte30hz
smpte50hz
smpte60hz
2160p50hz
2160p60hz
2160p60hz
Supported EOTF:
Traditional SDR: 1
Traditional HDR: 0
SMPTE ST 2084: 1
Hybrif Log-Gamma: 1
Luminance Data
Max: 0
Avg: 0
Min: 0
2
0
current vinfo:
mode: 0
width: 3840
height: 2160
field_height: 2160
aspect_ratio_den: 9
htotal: 5500
vtotal: 2250
fr_adj_type: 4
viu_color_fmt: 2
viu_mux: 2
3d_info: 0
present_flag 0
features 0x0
primaries 0x0, 0x0
0x0, 0x0
0x0, 0x0
luminance 0, 0
hdr_static_info:
hdr_support 13
lumi_max 0
lumi_avg 0
lumi_min 0
hdr_dynamic_info:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
metadata_version: 0
support_flags: 0
optional_fields:
hdr10+:
ieeeoui: 90848b
Mediainfo - Alita- x265sample.mkv
General
Unique ID : 25604837615930128793084330320268632814 (0x13434FF61369E3819D242C0B0E2C22EE)
Complete name Alita- x265sample.mkv
Format : Matroska
File size : 112 MiB
Duration : 28s 821ms
Overall bit rate : 32.5 Mbps
Encoded date : UTC 2019-07-23 19:01:01
Video
Format : HEVC
Bit rate : 32.5 Mbps
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.163
Stream size : 112 MiB (100%)
Writing library : x265 3.1+8-21db162c8622:[Windows][GCC 9.1.1][64 bit] 10bit
Encoding settings : cpuid=1049583 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=33089 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=2 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)cll=233,63 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Default : Yes
Forced : No
Alita HDR10+ metadata in json file if needed (not verified to be correct):
I’ve full logs if you want them @cdu13a
What you try to test that doesn’t exists yet. We are not there yet.
Right now the HDR10+ video plays in HDR10 with 3.14 kernel and SDR with 4.9 kernel.
cdu13a is working on it to fix this in 4.9.
The next step is to send the HDR10+ signal to the tv as HDR10+. I don’t know how much work and time is that.
[And the final step to send DV signal (little chance).]
Even when HDR10+ play will be supported your tv will not indicate that (as there is no HDR10+ logo), so it will be not easy to notice it at all.
HDR10+DV.m2ts is an untouched file from the Alita UHD BD.
It contains the main video stream (with HDR10/HDR10+ info) and a Dolby Vision substream.
My LG tv has no problem to play it in HDR10. (as LG it is not HDR10+ capable by choice)
II, III, IV samples contains only the encoded(?) main video stream (without the DV stream as it is not supported).
The III seems the proper HDR10+ encode based on the mediainfo output, but mediainfo is not up-to date as it can’t recognize the DV substream. which is present on some BD a while ago.
I know that there is no implementation for HDR10+ in CE with 4.9 kernel. I did the tests so cdu13a has some data to look into this.
I’ve no need of Dolby Vision and I don’t think it will happen in the coming year, so DV is of no interest for me. A fun-fact is that playback of UHD Blu-Rays with a capable TV which support HDR10+ and DV will automatically choose HDR10+ and there is no option to choose Dolby Vision.
Regarding the HDR10+ logo. I’ve not looked into this, so I don’t know if some brands have a logo for it or not. The only way I can verify that my TV is receiving HDR10+ signal is by connecting my AVR which will display detailed information about the signal. Unfortunately, I can’t do this when using my TV’s internal player.
All the samples were found on forums, so I don’t have any more information about them beyond mediainfo and ffprobe. The purpose of the samples was that they should hopefully cover some encodes and files which will be relevant in the future regarding looking into HDR10+
sorry for being off topic, just curious, what AVR do you have?
Most of the latest AVRs can display audio and video signal information.
yeah but just bit curious, since I did not know any AVR supports this HDR10+ format (at least mine only supports HDR10 and dolby vision only afaik). My AVR only able to show information about the screen resolution and refresh rates (eg 1080p 50hz), the sound formats, channels, etc. Just not the HDR info , or maybe I dont know how to display more detailed info
Any update on the HDR10+ output on the N2
Work has been really rough this week. My job occasionally involves a lot of labor outside and it’s been high heat, high humidity here. Which has left me in a bit of an sore and exhausted when I get home. So progress is on the very slow side.
Hoping to finish a test build today that I’ve added a lot of extra debugging to which should help verify which of the two places in the code I suspect is the cause of the problem. After that I can make a fix and release a test build. Which will hopefully allow hdr10+ to be played back on devices that support it, and played as hdr10 for devices that don’t support.
Much appreciated. No need to explain, I appreciate all the work that you guys put in. Look forward to testing it for you
