CoreELEC IR RC6 Remote Kodi MCE out-of-the-box
Hello!
First Thanks @ all Developers and Members who make Coreelec so great.
I use it on a x96 with gxl_p212_2g.
What is the best and easiest way to get an HP MCE Remote RC6 (Kodi out-of-the-box) running with the x96 integrated IR?
On my OSMC and the HP MCE Remote RC6 + HP Pavilion HDX RC6 Remote
works Perfect.
I have the same remote. It should work with the internal remote sensor with default coreelec settings. Have you tried it?
I have add a x96 remote.conf to Enable the Original x96 Remote. Later I buy a RC6 Remote
What is the right way with a fresh installation to use the Original x96 and the HP RC6 Remote?
https://discourse.coreelec.org/t/mce-remote-with-k1-pro/2888
remove to /storage/.config/rc_maps.cfg and reboot. MCE works ootb with meson ir
Yes MCE works ootb with meson ir. Thanks
I remove the remote.conf and It works
which key names carry these two Buttons (Picture Kodi app red)
Key_???
