I use this:vfd.conf (1.2 KB) and it works great.
You can go to this link:https://discourse.coreelec.org/t/how-to-configure-vfd/427And use my file.
Iām sorry, but this doesnāt work for me. I donāt know if Iām doing something wrong or not, but the boot still stands on the screen
vfd.conf (1.2 KB)
Hi, try this, it works for him.
It doesnāt work for me either, but again I wonder if Iām doing everything right. Please if you can explain to me step by step what and how to do it.
There is a link three posts up that tells you how to do this. If the one in the repo doesnāt work, try searching.
Did you install the addon?
Yes I am interested the addon bat I donāt share how and wher to put vfd.conf file
The location you put the conf file in, is point 3. in the link
I know Iām annoying but how to get to that point Iām not very skilled with the Android tv box
Look, now 7 posts up in this thread for the link, then open link
point 3
Finally thank you all for your help
This remote.cofig file from @Tico post 03. Feb. works for me but some keys do not work, which are power, mute and mouse
My box has only a clock and it works.
I have uploaded the conf file from crkcrk to the remote repo
there are a couple of documents that will tell you how to create/modify remote.conf files
@tico How to arrange these few keys to work to make everything work 100%
Did you read the post above?
in the repo is a document telling you how to create a remote.conf or edit the one you have.
also in the repo, are a couple of S905X3 confs you can try.
Has eneyone tryed to install to internal on this box and if so what was the outcome.
Hello again.Iām going to install coreelec on a friendās Tanix TX3.Which image to choose?Stable or latest nightly?
Does anyone know which file to download on Tanix TX3 S905x3?
