Hello fellow community members,
I have a new Odroid C4 with latest CoreElec 19.5 running.
When playing video from the internet (on put.io), the viewing repeatedly stops and the screen returns to the list of videos.
I did find a 2-year-old thread with the same problem, but the fix suggested there - adding to config.ini: cec_func_config=β0β`- and a clean install did not solve it either.
Hope there are other options!?
Regards, Pieter
Try clean fresh install with CE-20, CE-19 is final.
Also cec_func_config
is handled by Kodi, so your settings get overwritten on next boot.
Thanks, Portisch. Installing CE-20 went fine, but a new problem arises: when I want to install a repository from USB-stick, the system does not recognize it. And I did try 2 different usbβs.
Put.io does not work either on CE-20.
Iβd like to find a solution that does not create new, other ones. So I return to CE-19.5 which at least worked - apart from the random halts during video playback.
Could anyone help with that?
Regards, Pieter
I guess itβs your internet connection itself.
But no log, no error
Hi Portisch,
Thanks, the error log is at http://ix.io/4kLw
The problem was reproduced today twice: at 5.45 pm and at 5.59 pm
