Every few stable/production releases of CoreELEC appear to lose the Ethernet network driver for the MINIX NEO U1 (s905) box.
In every instance, I verify the Device Tree/DTB is correct (gxbb_p200_2G_minix_neo_u1). I also attempt re-install several times to be certain.
The WiFi driver continues to work; only the Ethernet is affected.
In the latest 9.2.6 release (CoreELEC-Amlogic.arm-9.2.6-Generic), the Ethernet is again missing, along with all subsequent nightlies.
Could this driver be re-added to the ARM-Generic build?
Thank you in advance!
