Yes, but then you downmix the audio to 2 channels, and then upmix them back.
With AC3 transcoding, the system will transcode AAC to AC3 and it should, at least in theory, only have 1 stage of processing.
Interestingly it stops the stutter and freezing of the video, but there’s still no sound, so I’ll stick to PLII or maybe even go back to non-ng. Thanks for your time anyway.
I’ve got a Venz V10 box running smoothly on 9.2.8, tried upgrading to latest CE stabe & nightly, but device seems crashing ca 10-20seconds after boot. Sometimes I can see the Kodi setup wizard, but interface is frozen before I can enter anything.
Also sometimes, I don’t see anything on screen but if I keep pinging the device it shows periods of ca 15seconds with valid replies, folowed by a longer ‘dead period’, and after a while the cycle repeats.
I’m using the gxl_p212_1g.dtb (also tried a nightly with the _slowmmc.dtb, here the system got stable ping replies, but nothing appeared on the screen).
Is this S905L 1G/8G devices still supported? (edit: actually I guess it should, since I can select it from the download section, however it’s not working - on my device)
FYI: I also tried LibreELEC, and that’s running stable at the moment (only keyboard/wifi isn’t working, but I don’t need it).
Just wanted to share my experience, let me know if I should perform some other tests
That’s what I initially thought as well, but in the LE-forum someone told me it still is supported (also has the specific V10 device entry in the download-selector).
When I looked closer I saw only the GXBB was EOL, but GXL is still in the list (GXL is the dtb I used before in CE and now in LE, and GXL is the dtb which is proposed in de download selector).
S905L is listed in the EOL (GXBB) and STABLE (GXL) rows
Venz V10 was using S905 (GXBB) with 1GB Ram, so EOL.
Venz V10 Pro was using S905X (GXL) with 2GB ram, and still is supported.
As yours is the first one, you’r stuck with 9.2.8…
Actually I was doing some research for new hardware, so I’ll start that quest again.
If support is ended, maybe it should also be removed from the list of devices in the ‘Download’/‘New Installation’ on the homepage of CE? (both Venz V10 and V10 Pro are listed in there as a gxl device)
I use ce omega-ng build on my ematic jetstream with anyone of the p212-2g.dtbs and they all boot. Remote works as I had to custom configure it. Wi-Fi works and Bluetooth out of the box. Performs pretty well for an s905x rev d
