I want to install coreelec on this device https://articulo.mercadolibre.com.mx/MLM-924377551-x96-max-4gb-32gb-full-hd-4k-dual-wifi-s905x3-original-_JM#position=1&search_layout=stack&type=item&tracking_id=7341f6d5-4907-412f-9801-d2da247ed1a9 ,
It says it’s x96 max plus which is compatible I think but I don’t if it is compatible with that brand, it looks different but the model is the same, anyone knows?
I don’t recommend to buy X96 nowadays, as there are too many permutations.
See X96 Max Plus Q2 - WiFi doesn't work - #21 by rho-bot
I ended up Purchasing this model, and I was able to install coreelec with no issues, I’m enjoying my remuxes in 4k with passrhrough atmos.
Then you won the jackpot and got a device w/ original HW design. Enjoy CE experience
