Hi All
Been a Long long long time user of XBMC to Kodi on a PC and looking to upgrade my tv to a new 4k prob a LG G4 and have been reading a lot that my pc cannot support Dolby vision and many android boxes have the same problem until i was told by some helpful people in Kodi and avsforums that the AM6+ will. I would like some input before i commit to this device that now supports all formats.
so does the Am6b+ do
  1. All audio pass through to amp to decode for audio such as atmos and dtsx and all HD audios as i use passthrough on my pc
  2. Will Kodi and AM6+ do a better job at video picture quality than my 12 year old pc ati card running kodi meaning a much better image in SD, HD and 4K.
  3. Will the AM6+ auto fame switching like 24fps from 50
  4. Will it handle all dvd and Blu-ray formats from old encodes like mpeg2 and avc and other older Bluray and DVD formats
  5. Run all demanding skins in kodi ?
    6 have no lip syncs issues as I had a few with my pc and had to fix them using the advance xml.
    7 play the most demanding high bitrate 4K Blu-ray untouched rips
  6. Play web-dl Dolby Vison or any other HDR format
    9 play hdr10 and hdr plus or do you not need this support.
    10 plays SDR AND 1080P better than a pc can in picture quality as I have some SDR videos
  7. VC-1 codec blu rays what happens if there is a problem there and is there a way to fix it
    the VC-1 codec blu rays what happens if there is a problem like the shining, and is there a way to fix it as i have many olde Blu rays like
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
will these play
12 is there any problems with using a usb dongle and Logitech keyboard with tis unit
13. using any remote like a Logitech
14. can you leave this box running all the time or is it best to power it up from cold and can you boot Stright into Kodi
15. any problems to watch out for with this AM6+ or once its up and running it just works?
any other help would be great thanks
so is this the ultimate box to get now as can this finally replace the PC ? i have been told that the minix u22-xj might be better than the AM6+ is this true ?
And it’s the Ugoos AM6B Plus 2021 box as there seems to be three versions.
And there’s
Says 2024 version but link says 2021 ??
It’s their own official site I think something about 2024 firmware.
All yes, even the VC-1. I hear someone recently pushed a patch for progressive content :wink:
Specifically you can set to suspend instead of power off. For some reason running trim against freshly booted, triggers about 24GB in “writes” to the eMMC, at least according to iostat. Not sure if it’s actually writing when that happens, but if you leave it on/suspend it’ll only trigger incremental writes on subsequent runs.
And yes that 2024 box is nonsense rofl. Ugoos official firmware still 0.5.4.
No need to buy the specific “2024 updated” one.
I hope the ‘2024’ update doesn’t block DoVi in CoreElec…
I ordered the 2021 version less than a week ago. Should arrive next week. It’s just cleared customs.
the firmware on there site is dated 2022-10-14 11:14:00 so i dont know what this 2024 version is. why would they block options if people want to use the box the way they want.
what is the best place to buy this box in the uk
Probably only “Snake oil” :wink:
but is that not their official selling site ? trying to fig where to best buy these
Ugoos piggy backing off the AM6B resurrection.
AliExpress has been the go to for many here. Play TV has good prices on them.
Just wanted to add that I was also previously getting the 12bit DV bug on PM4K with no luck even when switching to smb pathing. With the bug, every DV title, regardless of profile, was playing audio only through PM4K even though they played just fine through PKC or the native kodi player. The latest nightly (which I assume includes the fixes in this test build?) completely fixed the issue and titles that’re played directly through PM4K are now correctly reporting 8bit. TV is an older LG B9 and everything is hooked up through a Denon x3600h. Great work as always @Portisch!
So you all bought from the Play TV seller at aliexpress ? , I noticed they have two versions which is £1 difference one states the Bluetooth the other does not dot understand why they have two up for sale as the title says
UGOOS AM6B Plus TV BOX Amlogic S922X-J Android 9.0 DDR4 4GB RAM 32GB WiFi6 1000M BT5.0 OTT 4K AM6 Plus TVBOX
the other
UGOOS AM6B Plus Wifi 6 Smart Android TV BOX Android 9.0 Amlogic S922X-J DDR4 4GB 32GB BT 1000M 4k TVBOX Media Player Set top box are the just the same. also did anyone get the different remote versions? I do have a Logitech harmony Hub and remote so not sure if i need the extra remote if i have these as i tend to use Alexa to tell harmony hub to turn on pc can this be done with this am6B Plus .
I cannot see anything about the flirc be used at all with this device? and can any usb keyboards as i have a Logitech Bluetooth dongle that a Logitech keyboard connects to
thanks just about to pull the trigger as just needing to know if there is anything i might need to look out
just ask parotec solutions for minix-unit. much better alternative. and uk-based company
thanks why is this a better solution over the am6+ as are these identical box and will both get the same future software updates that fixes the same issues meaning if am6+ gets the fixes like dolby vision support bugs the minix will
also is minix-unit just the same box but not locked, what’s the difference between the locked UGOOS AM6B Plus TV to the none locked minix as the minix doesn’t have encrypted bootloader. ugoos has encrypted bootloader what problems would this cause
depends on how mcuh the minix is as well as the amb6b can be had for £130
also a question we have all been waiting for a all in one box and why are these minix u22xj and am6+ that are 3 year old boxes now suddenly support and run everything just out on interest
From Australia cheapest was the Ugoos store with free shipping. They quoted up to 20 days shipping but it’s just cleared customs here in Melbourne in 5 days.
They all have BT as it comes with a BT/IR remote. You get.a few extra features with the minix since the bootloader unlocked.
at least one thing for sure: with Minix, you can boot off SD card but not an option for AM6+
also, because minix has 3 ports of usb 3
How does a lack of memory bandwidth make sense given 4k video works fine?
Because GUI isn’t the same as video. I don’t recall all the details right now, as we looked at it years ago. I’m sure that there’s some discussion about it in the forum also.
You can boot off and SD card for the am6b+.
I think that the S922X only supports one USB 3.0 port, so the extra ports on run from an internal USB hub as in a similar device.
Fixed second link
