was your internal build also based on the latest nightly or on older version?
I see that bit depth of 12bit is reported correctly for FEL now compared to the recent versions (official and CPM).
It’s based on the latest nightly with the CPM changes.
The Build works flawless👌
would you mind sharing this iteration of the skin? thx
@jamal2367 I dont see any link? I would like to try too
Waiting for CPM to share his build, ![]()
shhhh ![]()
Where can I find this internal builds of CPM?
"I hope this will settle, and CPM will share the great job he’s doing back again.
What is the use for this 9 “internal build” skin, when there is no internal build?
Btw, why both versions, 8 and 9, have the same “addon.xml”?
thanks!!! but where’s the L1 average metadata?
By internal build is meant if you compile it yourself, for example.
The original has the version 3.0.3 from BeatmasterRS. So that this is not overwritten by an update if it has been obtained from the Kodi repository, I have changed it to 9.0.3 so that there is plenty of space between 3.0.3 and 9.0.3.
Ooups, let me fix it quick.
Will release a hotfix in some minutes.
Am I wrong thinking that someone here has got this latest cpm build from someone?
or built themselves. There’s documentation on how to build CE, and since both repositories are open you can simply grab the changes.
@R3S3T_9999
Redownload the Release 9.
Fix is included.
thank’s a bunch. Will test in a few minutes
Maybe…
So this is only for the lucky skilled people who know how to build.
Unfortunately, I cannot share the build I have.
Someone else will have to do it. (self compiled)
Sorry if it comes across as a bit stupid.
Is this difficult for a layman to do?
Can you show how to do it yourself step by step? ![]()
