thanks again!!! really great info screen now!!
sorry one thing, which setting do you have to get these info here? I’m struggling with that view on my side episode number is a pain… and I don’t habe these info here as well
Hi, here is the arctic zephyr 2 resurrection mod skin (newest version find here)
Awesome, thanks!
Hi, here is the estuary mod-v2 modded skin
Modded for the @cpm A4 build
See in the picture.
Need install the kodinerds repo first for the skin dependencies.
Original skin for screenshots: here
There is two type of playerprocessinfo, when you use small osd, or not.
Save to your hdd, enjoy. :slight_smile:
Can someone help mod Plextuary found here:
Thanks in advance
Hi, its basically an estuary with very little modifications.
I merged for you the cpm estuary to this .
Here you go. :slight_smile:
Please PR subtitle language to cpm skin
How about underlay the percentages with a bar, the queues can move fast and maybe difficult to catch with figures.
For the CPU was thinking of having an alternative % text format say:
00 | 00 | 00 | 00 | 00
Keep them two digit from 00 to 99 in normal and maybe MX if 100, just to keep format length even and stop the text dancing.
Then can also underlay with a bar and align.
Yes the procentual value of the queues moving fast, I seen better in progressbar.
About cpu, in Windows just show the true total performance, not all core separate.
For CPU the int value as used by the progress bar is all core overall percentage,
With a small amount of cores also good to have the individual values to show the ARM big little core usage, over say 8 cores then less useful.
Hey frodo,
would you be able to also look into the fentastic skin for the player process info goodies:
Much appreciated :smiley:
Hmm… weird skin, its basically an estuary with modifications.
Here you go :slight_smile:
Thank you @frodo19
Arctic Fuse for CPM A4 Build and up.
Update:
Real Dolby Atmos (TrueHD only) and DTS:X detection added
Real time video and audio bitrate detection added (Advanced version only)
New audio codec detection added (FLAC, WAV, and more…)
Changing the name DD+ to its real name: Dolby Digital+ → Dolby Digital Plus
Modification of the video resolution structure: 3,840x2,160 px → 3840x2160p
Removal of the aspect ratio information
Update 2:
Addition of the Extended version
Basic version:
Advanced version:
Extended version:
I still can’t take screenshots in HDR/Dolby Vision without issues, even when I set the interface to 1080p. :sweat_smile:
Download:
Basic Version: 48.21 MB file on MEGA
Advanced Version: 48.23 MB file on MEGA
Extended Version: 48.35 MB file on MEGA
PS: The detection of Dolby Atmos (eac3) is still done by identifying the codec (eac3) and the number of channels (8). This method is not precise.
A big thank you to @anon95383068 (VS10 Status) and @frodo19 (bars).
I thank once again the community who are doing incredible work. :heart:
Could someone tell me why when I take a screenshot in HDR/Dolby Vision, the rendering is buggy?
Can someone confirm if using doublewrite mode actually degrades video quality though, or what the default mode is to ‘reset’ that setting?
thank you so much!
We also thank you for your efforts. Would you be able to do for Arctic Fuse and more detail with all the information like those laid out above for the other skins.
I’ll make an Extended version when I have time.
For which skin? Or you mean you’ll add the plumbing for skins to show this info? I share your surround music interest!
