Is this for everyone or for Enet who had issues with HDR/SDR?
Update : i guess everyone as the timestamp of v20 is now about at the same time when you posted the above message. So everyone should grab it again, correct ?
Since @cpm says “Last release for a while barring major issues”, I presume that he will make a final build when CE finishes and publishes CE21.2-ng Official.
That is quite possible. :+1:
with the latest a10 cpm my black screensaver isn’t working anymore. with a paused dv movie the screen is not really black anymore it’s some kind of background light that doesn’t turn off. with non dv stuff it’s all good.
any thoughts? thanks
which is not perfect for a oled of course… workaround is to leave the movie with stop then after 1 min my screen is perfect black…
This is normal because in case when you stop the movie, your TV switches back to SDR (lower overall brightness) and if you pause a DV movie, your TV screen stays in DV mode which is of course much brighter. So you have to set Black Screensaver to a much lower value to have the same reduced brightness as with SDR.
hi thanks but I cannot set anything with that screensaver it’s just called ‘black’, no settings available.
with a9 and 100 other cpm and ce nightlies I never had that problem
Always been like that with any build.
100% not. maybe you are using another screensaver. it’s impossible to oversee that Grey and I’m using ce with that black one for 6 months now. I have many dv movies and episodes
Nop, it’s been like that even with the old CE-20.5 at least with the AZR skin. My TV is in a pitch-black room and it annoys me so I never pause a movie in DV.
My bad, I thought you talked about “Dim”, which I use instead of “Black”. I set Dim to 1%, and it works the same on my LG Oled with SDR & HDR/DV TV modes.
I know now why we are not aligned here. you are right and I was right. what the hell… just rolled back to a9 with the previous skin update 19 for azr and colored icons and same problem. then I realized that I have a new tv since yesterday :slight_smile: 65c4 and that tv stays indeed in dv while my 7 year old 65b7 was obviously somehow avoiding that because I’m 100% sure it was pitch black
that’s sad! now I have to take care of pausing :frowning:
or maybe it’s because I just turned off that annoying tcp and gsr via colorcontrol. but yesterday I saw a non dv movie so I cannot tell
@anon95383068 : Do you have a newer version up on GH ?
I see the timestamp of the zip is only 8 hours old
Hi Jamal, a big thankyou for all your hard work, would it be possible to add a scope feature for people with older 16:9 projectors to your fantastic skin. My jvc dla hd750 is 16:9 and I am currently using the skin below. But love the cpm features with your cpm/artic zephyr reloaded skin.
Yes, bug fixes or small changes are made and replaced the .zip file. Just check GH from time to time to see if there is a new timestamp. Then you know it has changes.
Thank you, makes sense.
Even during video playback, blacks are raised with VS10 for SDR in the CPM builds. E.g. the matte black bars are just not perfectly black (DV-capable OLED, Am6b+). On native DV videos, it’s 100% black.
hi would it be possible for you to explain an idiot like me how to get rid off some text in the player osd?
I have 3 texts rotating
  1. season x + episode y
  2. feature ends at 123
  3. paused
which drives me crazy I only want to see season and episode (I see that it’s paused and feature ends info is already available on the right side… :wink:
so all I have to do is deleting some text in a specific txt file?
Arctic Zephyr: Reloaded for CPM A11 Build and up.
Can be installed over the current one, then reboot.
Changes from 20.0 Final → 21.0 Final:
  • VS10 mode button added to Video OSD for on-the-fly conversion.
  • Codec logos detection improved.
  • German language updated.
  • Polish language updated.
  • Chinese Traditional translation added.
  • “Close OSD automatically after (in seconds)” has been extended. (1-30 seconds)
  • “Show detailed information when starting the video (in seconds)” has been extended. (1-30 seconds)
  • Audio codecs are now displayed correctly in the Video OSD.
  • The title in some dialogues when the text is too long has been corrected.
  • When using the vertical menu with icons, the text was too large.
  • Latest changes added from BeatmasterRS his Repo.
  • Bugfixes.
Screenshots:
Important:
Please note that this version is the final version and there will be no further updates in the future.
Download:
Link
Enjoy! :slightly_smiling_face:
To all:
I have just uploaded the correct Release21 zip file after mistakenly uploading the wrong one. Please download again.
