I will soon finish the Extended version, and I will publish the correction for Arctic Fuse 2 at the same time.
I’m trying to do it as quickly as possible.
I just added the Extended version for Arctic Fuse 1 and 2.
I just updated the links with the latest version for Arctic Fuse 2.
Yes, the green FEL label shows only that the video has it, not that it’s actually used.
Hey, awesome work, but the archive structure is wrong as skin.arctic.fuse.2 folder should be the root of the archive with no higher-tier folders, otherwise it will give an error on an attempt to install. Any chance for Arctic Horizon 2 to get the same treatment, too?
I’ve just modified the folder structure. I now provide only the files needed to have the modified Player Process Info, rather than the entire Arctic Fuse 2 folder, as it is updated daily.
Extended Version added for Arctic Fuse 2.
Arctic Horizon 2 for CPM A4 Build and up.
Basic version:
Advanced version:
Extended version:
Download:
Basic version: 46.26 MB file on MEGA
Advanced version: 46.26 MB file on MEGA
Extended version: Dolby Vision Profile, VS10, plus other info on skins - #154 by Nestya
I thank once again the community who are doing incredible work. ![]()
Extended Version - super ![]()
You do plenty yourself, thank you very much.
is it not possible to have an indication for the actual fel usage? I mean that fel is THE usp for the whole ce journey - besides that it’s not sold ![]()
Why you ask this?
When use the cpm build in fel supported box, and the source include fel, than the output correctly include fel.
No need other indication.
great! I have no clue that’s why I was asking if the green fel indicator says it’s there or if it’s also used ![]()
I’m running a ugoos am6b+ with cpm build 4.1 I’m sure everything is great and I’m very thankful.
I will never have pictures to compare or even equipment to measure something on my oled.
I just think the picture is superb, and I was wondering if I would think that too without fel … I was happy with picture quality with shield and zidoo some years obviously without fel I didn’t know at this time ![]()
And we thank you for your work. Will it be possible to add the CPU temperature in the Extended version?
Which skin?
Arctic Fuse 2
I’ll integrate it, it will be ready in about 10 minutes.
Extended version with CPU temp for Arctic Fuse 2
Thank you.
I tried the files, they also work for Arctic Fuse 1.
Is there any difference in the files between the two skins?
