Thanks for your post…
Please, help us to solve this problem, Wifi not working & BT not working…
Wifi: Realtek RTL8188FTV
Linux Kernel 3.14
Linux Kernel 3.14
You’re still using Leia and that’s EOL. For that there won’t be a fix provided by CE. You have to upgrade to Nexus.
My receiver can’t read the tuner after upgrading to Nexus.
So, from your experience, give me some advice to solve this problem.
I use now Linux Kernel 3.14, coreELEC : devel-1687364946
http://ix.io/4Ele
WiFi: Realtek RTL8188FTV (doesn’t Work)
Use an USB wifi stick. Or if possible, don’t use wifi, it sucks.
I already used USB wifi but it has the same problem where not appear any wifi connection… it nee to identify within linux system.
I think the receiver can not compatible with the newer system due to the absent of tuner or disappear after upgrading…
Because you need to manually install DVB add-ons from repo…
Please, can you give me the file: gxl_p231_1g_m8s_dvb-s2.dtb
Write the image and you will find it on SD card or USB stick where you wrote image.
Ok I will do that. But after writing the image, then setup in my receiver, is it need to add any codes to dtb or the corelELEC will do well…
I am so sorry for more question, our receiver called DreamMax B9S2X… amalogic S905d
Tuner: montage m88RS6060
We need support from you to change from this receiver… more than 2000 persons want that.
Thank you so much.
Where can I see that?
Only 2.000 ? ![]()
Are You seller of this devices ?
There is a group on facebook contains more than 2000 persons, all want to work with newer coreELEC system for the mentioned receiver. I write here to find solve for our receiver.
More than 2000. I’m not seller. I’m normal user for this receiver.
I have a same of this device dreammax b9s2x and i hope support it
I really doubt anyone from CE team would do any development for such old device.
Maybe for really big bag of
Hope we find out as solution for our topic here one of few thousand that want support for this device
Please, we need support from you and your group to solve such this problem. We really appreciate any effort for that.
2000 users * 4 € = 8.000 €
Would this be ok?
This is just to increase interest of someone for faster help. And nothing else.
