DreamMax B9S2X
ا have the same device dream max b9s2x ,Please help us , support it.
First you will need to help us before we can help…
I burned the coreELEC 20 on the flash and changed the dtb, unfortunately it does not appear as in the pictures and does not boot…
What I can do?
Follow the wiki
https://wiki.coreelec.org/coreelec:devgeneric#generic_devices
https://wiki.coreelec.org/coreelec:ceboot
Which Boot method did you use?
I suggest to use the “Reset Button” method, on your device this is the “recovery” switch on the bottomside of your device.
Unfortunately, all methods did not work for me.
Did you try restoring the original Android image first?
Then maybe the android base (BL CE relies on) is too old.
What’s the Android version currently on the box?
Yes, I did and did not work also.
Android version 7
Which subversion? should be min. 7.1.x or higher…
Based on coreELEC 9, can you repair this dtb file to work with my wifi? All things are okay, but WiFi doesn’t work… my wifi is Realtek RTL8189ETV
http://ix.io/4Ele
b9s2x.dtb (40.6 KB)
Thank you.
No, CE-9 9.2.8 is EOL.
Use CE-20, Amlogic-ng
https://wiki.coreelec.org/coreelec:ce_dev_cycle
And again:
