OpenBOR is not supported on Addon version, it need a kernel patch that is not available on CE
Hi. I have managed to configure the iagl addon to open the games with emuelec. The problem is that it does not use the emulationstation interface, it uses the retroarch interface, and it does not take me the configuration of the Xbox 360 game controller. In emulationstation I have it configured and working. Does anyone know how that configuration of the remote control could be passed to retroarch, so that when it is started it is configured?
I am running EmuELEC on my x96 Air (S905X3). It runs exceptionally well. Flycast needed to have dts audio disabled to fix some stuttering, but otherwise runs 30fps. Can this be the default setting?
Sorry, no idea I don’t use IAGL so I do not know how it works.
does this setting not stick once you change it?
Thanks for answering. No problem, I will continue investigating. I have another problem. For some reason I don’t know, the sound does not work in emuelec, in the menus or playing. I have connected an X96Air (S905X3) using spdif, and in kodi I have no problem with the sound. I have changed the audio options within the addon, tested with several, but none gives me sound.
The setting sticks, but I would like to roll it into the build. My experience with retroarch is mostly as a user. If you can point me in the right direction in which package this should be set, I’ll put it in my fork. Then you can accept or decline a PR as you see fit.
As far as I know that setting should be set here
Firstly thanks for all this. Struggled bit but have enjoyed getting back into retro games.
Can’t get 3do games to show. Put iso’s in 3do folder and nothing. Looked on es_systems.cfg and 3do not in there. I must be missing something. Nobody else having problems
I haven’t tried 3do, but the libretro docs are here: https://docs.libretro.com/library/4do/
please release 3.4 addon Version
Would it be possible to get the Play! core for PS2 emulation included in the next update?
3DO only works for Amlogic-ng, and not that good unless you have a s922x
Is there something in particular that is not working for you? I will release a new version, but there hasn’t really been anything new to add yet.,
That explains why 3do not there as have version for my x96 mini
Having trouble with MSX. Have bios files in correct location. Hangs if rom is zipped. Just fades back to list if unzipped. Tried ROM from different download and same. Looked at last log. Last entry is “Segmentation fault”. Others have marked this as working (and MSX 2).
Hello, everyone. I’m new here. What’s the difference between Amlogic-ng and Amlogic? My device is GT-King, so which firmware should I choose?
-ng version is for your box.
Having same problem with ColecoVision as MSX and both use same MSXblue core according to log.
Needs bios
