Error updating Corelec
Cannot start Corelec after an update to 9.2. my device is the GT king andriod box.
Error message attached to this thread. Need step by step instructions on how to reinstall corelec.
Probably you have wrong dtb.
Connect your sd card to PC and just replace dtb.img with correct one from device_trees folder. I think your current dtb is for rev. B, but you need rev. a dtb
Ok, let me ask though can you give me a step by step instructions on how to do this,
Do I have to download the whole image again ?
Please read the part about dtb
can you please advise which of the images I need to download I have a Beelink gt king
g12b_s922x_beelink_gt_king_rev_a
or
Are the options for GT King.
thank you all sorted
