Hi all,
I’ve made an experimental CoreELEC 22 NO patch that converts Full-SBS (3840×1080) and Full-TAB/OU (1920×2160) into genuine hardware decoded HDMI 1080p frame-packed 3D.
It is currently working well on my Nokia Streaming Box 8010 / S905X4 with an active-shutter projector.
Both eyes are output at full 1920×1080 resolution, and normal MVC 3D still works.
The feature lets VD1 and VD2 read the two eye regions from the same decoded frame and feeds them into the existing Amlogic frame-packing path for full hardware decoding.
UPDATE: I’ve added vertical shift support for MVC Blu-ray 3D, Full-SBS and Full-TAB playback, allowing the 3D image to be moved vertically while keeping both eyes correctly aligned.
UPDATE 2: Added scaling corrections for external .srt subtitles being stretched (HSBS) and made narrow (HTAB) during 3D playback. Also fixed the wrapping for longer lines that was cut very short in HSBS.
Also, it detects filenames like FSBS,FTAB, and OU as 3D.
It is currently based on the NO-codebase from Oct 28. So it adds newer fixes including Portisch’s fantastic MVC macroblocking fix.
Just put the .tar file into /storage/.update/
Included is also an F-SBS and F-TAB sample, that will show if the two eyes are working and shown in full HD - based on pixel patterns, where you should be able to see 1-pixel lines.
