Does the CE tool add the reboot to emmc option? And is the option to reboot to CE
also in Android? This seems like the main thing that is needed for simplicity sake.
In default CE skin you have this option by default.
In Android a logic will be different. After reboot you return to CE.
Thank you - yes, had seen that - the one part that is not clear from the instruction (just simply reading it in the guide) is how you execute the options - but it all becomes very clear once you in fact execute the initial command - it indeed lists the available options for the EMMC status it finds and then instructs to select from [1,2,3,4] and you simply enter the number and execute - I think that very last step could be added to the on-line instruction. Again, it IS obvious once you start, but adding it in the instruction would just be helpful to complete what to expect - itās obvious in hindsight but looking at it beforehand it just wasnāt clear how the options would be executed.
Not a criticism at all, just a first-time user of the tool perspective.
And yes, it was indeed super-simple!
It looks like you would execute option 6, then option 7 (two separate operations it appears) then option 1 again to re-install after the Android update
Itās not as much of an inconvenience as I perhaps initially perceived.
Nice job CoreELEC Team
v0.3.3 has been released as a RC
- Fixed work of multichannel high resolution PCM audio
- Added saving display mode after turning off/on the TV with AV receiver
- Now default display mode for applications equals resolution in settings
- Now Lock UI size function worked for all display modes
- Applications will not be redrawn if enabled Lock UI size function
- Fixed screen rotation for non FullHD interface
- Some wallpapers are copied to user folder
- Added Fake Wi-Fi function
- Fixed some crashes of application TvSettings
- Added horizontal recent apps window as option
- Fixed not worked TV volume control by CEC in some cases
- Fixed h265 playback crash
- Fixed interlaced video stream jitter bug
- Fixed display freezes and becomes slow/lags while selecting PIP mode options in VLC app
- Fixed freezes when playing 8k video (X3)
- Ugoos remote changes:
- added quick connection menu
- added joystick menu
- fixed work with third-party keyboards
- added multi-touch to the touch screen
- added button on-off vibration
- added button power off TV box
- other changes
Dualboot build with CoreELEC
- Increase CoreELEC partition size to 3GB
- Replaced CoreELEC night build to stable 9.2.2
Looks like they listened to BOTH of my requests - now that is service!
However Iām not sure I will swap over to the full Ugoos Dual Boot firmware - now that I have the CEEMMC capability installed and both OS configured itās actually much more convenient to use CEEMMC to update both independently (vs having to now burn the Dual Boot and then re-configuring my Android)
Does anyone know what the relative ālost spaceā is for CEEMMC vs the Ugoos Dual Boot config? Are they the same?
(Itās actually not an issue for me - just curious)
Space is not lostā¦
You could check the space with command df -h
The disadvantage is that not all memory of the internal eMMC can be used. Around 5GB of the internal memory is lost in this mode because of the Android partition layout. The amount of lost memory depends on vendor/device.
This is the part that is confusing
Android partitions use some space that couldnāt be used in dual mode by CE. This is jist a comparison with CE single mode installation.
OK I think I follow
Have to say that note about the 5G ālostā is very confusing statement and could be better clarified - just a well-intended constructive comment.
As written it gives the impression that when you install CEEMMC Dual Boot - you are going to lose a new 5G of unusable storage in addition to the CE requirement AND the Android system
So perhaps a better statement might be:
In a Single Boot CE installation, the Full Storage Volume will be allocated to CE
In a Dual Boot installation there will continue to be a reserve of approx 5G for the Android allocation, leaving the remainder available for shared storage.
