I’m super new to the CoreElec, just got it installed on internal of my GT-King Pro and for some reason I have no sound on my 3.5jack, I can’t check HDMI/Bluetooth, because right now I’m out of devices with speakers on those outs. I tried switching all audio modes, none produced any sound, nor system kodi sounds, or any movies or airplay streams… any ideas where to poke ?
Thanks for answering, yeah I tried all available modes
I’m not sure how to use nightly builds though, the link from welcome page doesn’t feature any builds, only archive folder has some, any guides how to use nightly build properly ? Any way to install them from already installed CE on internal ?
Maybe take a closer look at your 3.5mm audio jack, if it’s wiring confronts GTKing’s connector.
It’s a know thing that different manufacturers use different order in wiring these connectors.
No, this is just a device tree. Save it on your computer and copy to your gtking-pro in some folder (like downloads). Then overwrite original device tree.
mount -o remount,rw /flash
cp /flash/dtb.img /flash/dtb.img_orig
cp g12b_s922x_beelink_gt_king-analog_sound.dtb /flash/dtb.img
mount -o remount,ro /flash
sync
reboot
