You think the SD card is broken within the device? Can I just do a factory reset and try that way?
I have not placed anything into the device storage myself so I dont want to delete important files on there. Not that I can find anything to delete anyways.
Glad you bought one. As far as I could tell, the CoreELEC team originally did not plan on supporting 3D MVC because it believed it an obsolete feature, but enough calls for 3D support prompted a rethink.
I had a Zidoo device and itâs now sitting itâs box probably never to be opened. Except for DSD, I donât think thereâs a single feature on the Zidoo that the AM6B+ will not implement by the end of the summer.
Amlogic now has a challenge to release another chipset that exceeds the S922X-J. For non-streaming content, the S922X-J is absolutely perfect and exceeds even the most expensive disk players.
Because this is the internet my friend, people say things without ever having actually done them. I was just wanting to confirm.
Itâs confusing how it doesnât work for a few of us, but does for you when weâre all running the same build. Both my Denon AVR-X6700H and my LG 65Q soundbar do not recognize the stream coming from the device, across multiple videos. Itâs additionally confusing when I can swap in an N2+ with the same CE Audio settings and everything plays fine. Iâm going to try a full re-install for kicks
Use other pendrive, with fresh install.
I use the last nightly devel version.
I have lot of other boxes, but really like this, to the local play,
and the cpm devel version add me more featuresâŚ
The team made awesome work on this
The problem was resolved after I reset the receiver. I donât what exactly what went wrong but it seems that it was receiver problem , not coreelec settings. The setting was not changed (audio passthrough enabled with every options turned on) and everything worked, including dolby atmos, flawlessly.
That is what I was trying to explain before.
You had engaged the DTS upmixer called Neural:X on the AVR.
When that mode is selected on your Denon the AVR will discard the Atmos metadata.
You could have pushed the yellow (?) Pure button on the AVR remote until it said Auto and you would have got the Atmos back.
Or the green (?) surround button until it said Dolby something.
Wow thatâs really small. 32gb SD cards are super cheap these days. Nice to have one on hand. I would imagine youâll run into problems real quick with that once the .tar is unpacked and any add-ons or updates happen.
echo Y > /sys/module/hdmitx20/parameters/dovi_tv_led_no_colorimetry
Yes, without it your TV will still do TV led Dolby Vision, this is just a slightly more correct color flag, but most TVs ignore the color flag anyway. Do it if you want or donât. It probably wonât affect anything.
