How do i make the Ugoos AM6B+ output 422 instead of 444 in hdr10? I read that 422 is preferable for my sony tv.
I have a Sony TV, can you point me to the article on this?
It was discussed on avsforum a while back. I dont remember the link to the comments though.
Today i turned on the AM6B+ running CoreELEC 21.1 061624 and the GUI was suddenly at the lowest resolution and minimized to a small window. I went to Resolution and change it back to the default 1920x1080 and the GUI went back to full screen, but the letters became stretched horizontally. Any ideas why?
It just fritzed as I honestly donāt think CoreELEC is all that stable. For example, I recently had installed and used a nightly for about a week (on SD card) with no problems. Then one night my am6b+ wouldnāt boot into CoreELEC but remained stuck on their big logo that comes up during booting. The logo just spun spun spun and no better what I did (unplugged ugoos tried resetting etc) it still wouldnāt boot. So yanked out the SDcard and took the opportunity to format it and stick the newest (19th) nightly on there. Then it booted. Why did it stop working before that? Who knows
Could always be a sdcard problem such as data corruption caused by a bad write.
Yes, who knows? Nightlies are by definition not stable. In other hand I run nightlies of NO and NG in four different devices and I donāt have any major problems.
Of course that thereās a weakness in the setup and thatās the card. It can get corrupted.
That was just one example of when I had problems. Have had many instances of having to unplug the ugoos and reboot because CoreELEC āgot stuckā froze. So hmmm, you are saying you are having less such problems? This has got me thinking to perhaps I should use something different than rufus? Can you suggest please?
Itās not about Rufus, it really is most likely a bad SD card.
Your best bet is to move you CE install to the eMMC memory using the ceemmc tool.
Alternatively, you could try to use a high quality USB stick instead of an SD card, they tend to behave a lot better.
Dang, I bought three new SanDisk Ultra 32GB microSD HC Class 10s just for this whole ugoos project. Ya, I plan to do that ceemmc stuff once I get smarter and CoreELEC for the am6b+ becomes more āmatureā shall we say
Thanks for the USB stick suggestion. I will try using a USB3 stick after the very next āfreezeā & then report back.
Iām using a nearly-2-decade old usb stick and CoreELEC is running fine.
Almost never. And when it does happen, it usually is a bug with PM4K as it may not exit cleanly, or freeze.
Hello Everyone,
AM6B+, CE 21.0, Sony X90J TV.
When I first play the movie below I get the screen as per below. I have to stop the movie and restart it before it will play normally. Any suggestions appreciated.
EDIT:
Here is the dispinfo on the first attempt to play - https://paste.coreelec.org/RepeatedBearings
Here is the dispinfo after a stop and play - https://paste.coreelec.org/CuddlyLoathe
BTW - Both of the above dispinfoās are identical.
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 27 min
Bit rate : 19.1 Mb/s
Width : 3 840 pixels
Height : 1 920 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.108
Stream size : 11.7 GiB (95%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 965 cd/m2
Maximum Frame-Average Light Level : 258 cd/m2
Use nightly
Thanks for the reply, itās appreciated.
Are you saying that because you know thereās a fix in the nightly, or just to see if the same happens with the nightly?
EDIT: Just tried CoreELEC-Amlogic-ng.arm-21.1-Omega_nightly_20240621-Generic.img on a USB and the same result.
Interesting topic, Iāve found this post with a quote from Stacey Spears
Every consumer display I have looked at will convert RGB to YCbCr and 4:4:4 to 4:2:2 for internal processing. LG has a true 4:4:4 mode that many call PC mode.
Others on avs forums seem to suggest the same thing, i.e., this post
If I recall, Sony processes HDMI inputs in 4:2:2
[IMG_9212] is anyone here has green screen weird color on HDR10+ videos ? Weird green screen will appear if I played HDR10+ video after the devices powered on / after reboot. to fix the issue I have to stop the video and press play again then green screen just disappear by itself ā¦but after reboot device green screen comeback again. Ugoos am6b+ / Nightly 20240529 / LG C1 Example: Video ID : 1 Format : HEVC Format/Iā¦
Same issue here with my LG C1 ⦠seem like when you played HDR10+ contents on the TV that doesnāt support HDR10+ ⦠the first attempt you will get green screen color need to stop the video and play to fix
Thanks for the reply.
So what is the cause of this as my N2 running CE21.0 never had this issue? Hardware?
I had this issue on my N2, and since stooping/starting again fixed, it never bothered me much.
assuming your CE is installed to EMMC on your first box.
plug in SD card, run ceemmc -x, back up to SD card
plug backed up SD card into new box, run ceemmc -x again and install to emmc
will be good to go after, everything is included, add-ons and config
This worked perfectly. A godsend, really. Thanks again for your help.
