Guide to CoreELEC, Tailscale and Jellyfin setup
I collected my notes on setting up CoreELEC to talk to Jellyfin over Tailscale.
Might be useful for others, there are a couple Tailscale gotchas that can be confusing, and I couldn’t find an existing guide with all the basics in one place.
It’s here:
Thank you for sharing. Sadly I recently learned that running Tailscale on my CoreElec box disconnects all my Docker containers (no network at all) running on the box.
Interesting - so you definitely can’t reach them via the Tailscale IP either?
I don’t currently run anything Docker on my CE boxes. I suppose an alternate approach to try would be to run Tailscale in a docker…?
My main use of Docker on CoreELEC box is to make backups (via borg + borgmatic). There is no need to access the container externally - hence running tailscale inside container environment does not make much sense.
Edit: turns out that this only happens if I have an exit-node configured.
Interesting - is the exit node on the same subnet?
I only tested very briefly but was able to use an exit node on the same subnet without immediate issues.
I really only want Tailscale on my CE boxes so that I can access Jellyfin, across Tailscale, from outside my home network (which is what I imagine most folks would want). I doubt worrying about the small amount of network traffic exiting a CE box makes it worth bothering with an exit node in this context, for most people (unless you’re using P2P or something, on your CE box, I guess).
