Using an Infrared Remote Control with CoreELEC
This tutorial explains how to configure any infrared remote control with Kodi on CoreELEC, using the box’s built-in IR receiver. It works regardless of the remote’s model or brand.
It does not directly apply to Bluetooth, RF, or other types of remotes.
Since recent CoreELEC versions, some buttons could not be mapped (for example “Power”, etc.).
The method relies on the rc_keymaps, rc_maps.cfg, keymaps, and Lircmap.xml files.
A) Configure data transfer between PC and CoreELEC box
Remote configuration on the CoreELEC box will be done from a computer.
1. Enable SAMBA
FROM Kodi:
Settings > System > Note the CoreELEC IP address
(I recommend configuring a static IP from your router/box interface)
Settings > Services > SMB client >
WINS server = 0.0.0.0 (leave as is)
Minimum protocol version = SMB2
Maximum protocol version = SMB3
WS Discovery = enable
Settings > Add-ons > Program add-ons > CoreELEC config:
Enable SMB 2 and 3
Password authentication = choose a password
FROM PC (Windows 11):
SMB v1 is a vulnerable version and should be avoided.
Disable SMBv1:
Windows > Control Panel > Programs and FeaturesTurn Windows features on or off
In the list, uncheck “SMB 1.0/CIFS File Sharing Support” -
Enable SMB Direct:
In the list, check “SMB Direct”
OK > Restart LATER.
Control Panel > Network and Internet >
Ethernet > Check “Public networks”
Ethernet > Authentication settings (Change) > Add IEEE authentication > Change >
Add a trusted server name = COREELEC -
Advanced network settings > Advanced sharing settings
Private networks:
Network discovery enabled
File and printer sharing enabled
Public networks:
- Network discovery enabled
- File and printer sharing enabled
2. Enable SSH
CoreELEC > Settings > Add-ons > Program add-ons > CoreELEC > Services:
Enable SSH = On
Disable SSH password = Off
SSH password: choose a password
Default SSH server port: 22
Default username: root
Default password: coreelec
IP address is listed under Connections -
Install PuTTY
Host Name (or IP address): enter the CoreELEC box IP
Port: 22
Saved Sessions: choose a name for the connection
Click SAVE.
Connection procedure:
- Select the previously configured session > Load > Open
- Choose “Yes” to accept the host key (only needs to be done once)
- In the terminal window:
username: root
password: the SSH password chosen in CoreELEC
B) CONFIGURING REMOTE FILES
1. Disable CEC in CoreELEC:
- CoreELEC Settings > Hardware > CEC wakeup option
- Kodi > Peripherals options
2. Get the new remote’s scancodes:
- Open PuTTY and connect to CoreELEC.
Paste:
systemctl stop kodi
systemctl stop eventlircd
ir-keytable -p NEC,RC-5,RC-6,JVC,SONY -t
Press all buttons on the remote (from left to right and top to bottom).
This will generate scancodes in the PC terminal, like this:
500.027674: event type EV_MSC(0x04): scancode = 0x70702
500.027674: event type EV_SYN(0x00).
etc… and so on…
The generated scancode above is therefore:
0x70702
- When finished, copy all the content generated in the terminal (Ctrl+C) and paste it into an AI.
Ask it to generate a simplified page in the ORDER given, with the following header and formatted as:
\[\[protocols\]\]
name = "mecool"
protocol = "nec"
\[protocols.scancodes\]
0x70702 = ""
0x70701 = ""
0x70704 = ""
etc..
etc..Copy the result into a text file and save it as “remote_name.toml”
3. Create the remote configuration file
Since you previously generated the scancode mapping by pressing the keys in the indicated order,
you will now enter the corresponding key name between the quotes according to your remote:Example for a Samsung remote:
[[protocols]]
name = “mecool”
protocol = “nec”
[protocols.scancodes]
0x70702 = "KEY_MENU"
0x70701 = "KEY_ROOT_MENU"
0x70704 = "KEY_1"
0x70705 = "KEY_2"
0x70706 = "KEY_3"
0x70708 = "KEY_4"
0x70709 = "KEY_5"
0x7070a = "KEY_6"
0x7070c = "KEY_7"
0x7070d = "KEY_8"
0x7070e = "KEY_9"
0x7072c = "KEY_TEXT"
0x70711 = "KEY_0"
0x70713 = "KEY_CONTEXT_MENU"
0x70707 = "KEY_VOLUMEUP"
0x7070b = "KEY_VOLUMEDOWN"
0x7070f = "KEY_MUTE"
0x7076b = "KEY_FAVORITES"
0x70712 = "KEY_CHANNELUP"
0x70710 = "KEY_CHANNELDOWN"
0x7071a = "KEY_F13"
0x70779 = "KEY_HOME"
0x7074f = "KEY_EPG"
0x7073f = "UNKNOWN e-manual"
0x70760 = "KEY_UP"
0x7071f = "KEY_INFO"
0x70765 = "KEY_LEFT"
0x70768 = "KEY_ENTER"
0x70762 = "KEY_RIGHT"
0x70758 = "KEY_BACK"
0x70761 = "KEY_DOWN"
0x7072d = "UNKNOWN exit"
0x7076c = "KEY_RED"
0x70714 = "KEY_GREEN"
0x70715 = "KEY_YELLOW"
0x70716 = "KEY_BLUE"
0x7073e = "UNKNOWN pic size"
0x70728 = "UNKNOWN picture"
0x70725 = "KEY_SUBTITLE"
0x70746 = "KEY_STOP"
0x70745 = "KEY_PREVIOUSSONG"
0x70747 = "KEY_PLAY"
0x7074a = "KEY_PAUSE"
0x70748 = "KEY_NEXTSONG"
You can notice that 0x70728 = "UNKNOWN picture"
means that no KEY was found for this picture button scancode.
You have the choice to let it stay like this or erase the line code.
Save in CoreELEC (via SMB file sharing) in:
“COREELEC\Configfiles\rc_keymaps\remote_name.toml”4. Create the remote association file
“COREELEC\Configfiles\rc_maps.cfg”which will contain:
meson-ir \* remote_name.toml
5. Configure keys
To map to a key using this method, you must:Example to assign the Shutdown menu to the remote’s POWER button:
In "remote_name.toml”, remote touch key is
(KEY_MENU will be the action corresponding to the POWER button’s scancode on the remote).
- CREATE: “\Userdata\keymaps\remote_name.xml”
- PASTE INSIDE:
<?xml version="1.0" encoding="UTF-8"?>
<keymap>
<global>
<remote>
</remote>
<universalremote>
<obc1>ActivateWindow(shutdownmenu)</obc1>
</universalremote>
</global>
</keymap>
You will notice ActivateWindow(shutdownmenu) where ActivateWindow(shutdownmenu) asks Kodi to open the shutdownmenu windows .
And <obc1></obc1> is the button identifier.
You can choose obc1, obc2, etc., as the logical identifier without it corresponding to a physical key.
So for each other remote key will use:
<obc2>other command..</obc2>
<obc3>other command..</obc3>
6. CREATE: COREELEC\Userdata\Lircmap.xml
- PASTE INSIDE:
<lircmap>
<remote device="devinput">
<obc1>KEY_MENU</obc1>
</remote>
</lircmap>
7. RESTART & TEST
From PC via SSH:systemctl restart eventlircd
systemctl restart kodiTest the keys & enjoy
if it doesn’t work Check first that the files code is properly formatted and free of junk.
