[ 224.476519@2] usb 1-1.4: new high-speed USB device number 7 using xhci-hcd
[ 224.600748@2] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=1a2b
[ 224.600750@2] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 224.600751@2] usb 1-1.4: Product: DISK
[ 224.600753@2] usb 1-1.4: Manufacturer: Realtek
[ 224.601087@2] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 224.604119@2] scsi host0: usb-storage 1-1.4:1.0
[ 224.742477@2] usb 1-1.4: USB disconnect, device number 7
[ 224.988542@2] usb 1-1.4: new high-speed USB device number 8 using xhci-hcd
[ 225.112837@2] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=c820
[ 225.112842@2] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 225.112844@2] usb 1-1.4: Product: 802.11ac NIC
[ 225.112845@2] usb 1-1.4: Manufacturer: Realtek
[ 225.112847@2] usb 1-1.4: SerialNumber: 123456
[ 225.227001@0] Bluetooth: hci0: rtl: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[ 225.227008@0] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821c_config.bin
[ 225.227142@0] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821c_fw.bin
[ 225.227982@0] Bluetooth: hci0: rom_version status=0 version=1
[ 225.228037@0] Bluetooth: cfg_sz 10, total size 31990
[ 226.129091@1] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 226.156351@0] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 226.156379@0] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Yes it works fine (although I only tested it with the system tools addon installed).
tbh, I still donât understand why udev behaves differently from autostart.sh, when comparing dmesg logs, the only different trace displayed is âusb 1-1.4: reset high-speed USB device number 3 using xhci-hcdâ (when it is stuck).
I suspect something is locking/attempting to mount the cdrom and delays usb_modeswitch (and that would explain why the delay is random).
With udev, the modeswitch happens immediatly and this shaddy âreset high-speedâ thing has no opportunity to trigger before.
