Please anyone make a dmesg | paste with this adapter with CoreELEC 19.2_rc3.
Your log link shows funhouse_2026.6 (9.2), not CE-19.
The log link is case sensitive, so maybe you had a typo.
Iām looking to get the same setup of odroid N2+ and the wifi module 5b. Iāll do a fresh install with the latest stable build. Is this a known issue with the current build? Will it likely be fixed in the near future?
Hi Portisch,
Thanks for your help - Iām still fairly new to this so hopefully the below log is what youāre expecting and helps:
EDIT: To clarify, Iāve applied the usb-modeswitch fix which works great, but still have the same boot delay + no bluetooth as the previous poster.
Sorry, new to this allā¦from what I can see the module 5b is not fully supported and needs some tweaking to work which causes a boot delay and the bluetooth doesnāt work. I am yet to buy the Odroid N2+ and wifi module 5b but will do so soon.
Iāll be shipping from Australia so wanted to make the right choice and buy it all together to save on shipping. I need wifi but not bluetooth. I like the look of the module 5b as it is quite cheap and seems fast enough but worried about the issues mentioned above.
Having not bought one yet would you recommend that I avoid it and buy another wifi adaptor? If so what is a cheap wifi adaptor that is 100% confirmed to work with Odroid N2+?
Thanks for the help
Dear all with this adapter: please try again with CE-19 nightly!
There is a fix included:
Implemented RTL8821A revision C Bluetooth device
The log shows clear the last nightly wasnāt used and it can not work:
[ 83.563106@5] usbcore: registered new interface driver btusb
[ 83.574527@3] Bluetooth: hci0: rtl: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[ 83.574533@3] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821a_config.bin
[ 83.574656@3] bluetooth hci0: Direct firmware load for rtl_bt/rtl8821a_config.bin failed with error -2
[ 83.574659@3] Bluetooth: hci0: Failed to load rtl_bt/rtl8821a_config.bin
[ 83.574661@3] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821a_fw.bin
[ 83.657409@3] Bluetooth: hci0: rom_version status=0 version=1
[ 83.657427@3] Bluetooth: cfg_sz 0, total size 17428
[ 84.048680@1] usbcore: registered new interface driver rtl8821cu
So again for the users:
Before report issues, try fresh/clean install. Try last nightly if it is already fixed. If still not working please post logs:
Thanks! Just wondering, would there be an expected timeframe for this fix to be included in the stable build? Just that I am ordering a N2+ for myself and another person so didnāt want to install a nightly for them.
Then you need to wait before you can use the hardware.
The release is waiting for TK what do have 3 months overdue:
Please use forum search function:
I did, I guess I didnāt do a good job with the search though. Thanks!
Edit: So I just received my Odroid N2+ with the 5B adapter and I canāt seem to get it working, I canāt see any wireless settings in CE.
Iām running the latest nightly from 20211005 and I did a clean install.
Do I need to do something to get it working?
Hereās a log.
Did you use usb_modeswitch program to put device from usb storage mode to wifi adapter mode?
Not sure what that means, so no
How do I do that?
Edit: Never mind, I solved it, itās working now.
Added the autostart.sh script above and installed system tools.
What @vpeter mean is your answer is found by using the search function:
Your log shows:
New USB device found, idVendor=0bda, idProduct=1a2b
Hello, I have simillar issue with wifi ( dont care about bluetooth) and fix it by autostart.sh.
But, I use coreelec 19.3, so my first question is why this improvement wasnt added to this release?
And second issue, which I have, is, that when I shutdown tv and power on it back, after that there is again no wifi. After restart everyrhing is ok, but it is very unpleasant behaviour, restart take few minutes:(
Thanks for the answer
Also using CE 19.3 with an ODROID USB wifi module 5B (RTL8821CU).
WIFI and bluetooth are fine after using usb_modeswitch in autostart.sh, however, it still has two issues:
Is it technically possible to have this dongle natively supported (without requiring usb_modeswitch) ?
If yes, how likely it will happen, and any tip how I could help/contribute ?
Thanks.
I doubt that because it just works as storage device by default. And needs to be put in wifi mode with usb_modeswitch.
Why the operation takes so long is beyond my knowledge (I never tested such stick). I just guess it should proceed much faster.
It seems the āLooking for active driversā step is the one consuming all the wait, and it is not consistent between multiple attempts.
Not sure if I can manage to skip it somehowā¦
Access device 003 on bus 001
Get the current device configuration ...
Current configuration number is 1
Use interface number 0
with class 8
Use endpoints 0x0b (out) and 0x8a (in)
USB description data (for identification)
Manufacturer: Realtek
Product: DISK
Serial No.: not provided
Sending standard EJECT sequence
Looking for active drivers ... <======= This step can wait up to 60 seconds
OK, driver detached
Set up interface 0
Use endpoint 0x0b for message sending ...
Trying to send message 1 to endpoint 0x0b ...
Sending the message returned error -7. Try to continue
Read the response to message 1 (CSW) ...
Response successfully read (13 bytes), status 0
Trying to send message 2 to endpoint 0x0b ...
OK, message successfully sent
Read the response to message 2 (CSW) ...
Response successfully read (13 bytes), status 1
Trying to send message 3 to endpoint 0x0b ...
Read the response to message 3 (CSW) ...
Trying to send message 4 to endpoint 0x0b ...
Sending the message returned error -1. Try to continue
Read the response to message 4 (CSW) ...
Response reading failed (error -1)
Device is gone, skip any further commands
-> Run lsusb to note any changes. Bye!
Can you do me one test if possible? But you would need cable connection.
Boot with ethernet cable and without wifi adapter. Run command
lsmod | paste
Then attach adapter and do command
lsusb -vv | paste
lsmod | paste
dmesg | paste
then run usb_modeswitch command to put adapter in wifi mode. And again run
lsusb -vv | paste
lsmod | paste
dmesg | paste
And post all the links you get.
1/ without adapter
lsmod
2/ attached adapter
lsusb -vv
lsmod
dmesg
3/ after usb_modeswitch
lsusb -vv
lsmod
dmesg
This seems to work:
CoreELEC:~/.config/udev.rules.d # cat 90-rtl8188gu_cdrom_mode.rules
SUBSYSTEM==āusbā, ACTION==āaddā, ATTR{idVendor}==ā0bdaā, ATTR{idProduct}==ā1a2bā, RUN+=ā/storage/.kodi/addons/virtual.system-tools/bin/usb_modeswitch -KW -v 0bda -p 1a2bā
for some reason if the modeswitch is run asap when plugged, it seems to be faster.
