Upgrade to Android 12, CE-NE21 Nightly works very well, thank you
@bluesea
Its homatics rosegold? How you can upgraded to this fw?
Yes, it’s rose gold, and it’s the firmware pushed by the manufacturer’s service staff
It was own request?
This fw include all dtshd and dts-x patch too?
Yes, I will have to provide the request myself and provide the serial number every time. Sorry, I don’t have an AVR and don’t know about the audio pass-through.
Allright, just was weird, because we not seen this build number in the alpha test group. thanks
I contacted the service staff at the factory and he said there was no DTSHD/DTSX patch.The timing of the next system update is also not known.
Almost my movies collection have 24bit 48 khz audio like this:
(Dolby TrueHD/Atmos Audio / 7.1 / 48 kHz / 3196 kbps / 24-bit)
But when playing, press i to show information, the audio line show only 48khz 8bit
Is there any down sample here, although set passthrough already
Could you explain who that “Service Staff” is? With who, and how, did you made contact?
I recently updated to Omega 3 and now during first boot my box is stuck with 100mbps instead of getting 1gig (on ethernet). A reboot fixes the issue. I used to easily get around 115mbps transfer on Lan but now at first boot im stuck at around 11mbps. After reboot transfer speeds are back to around 115mbps. Not sure if the driver is not loading correctly or something in ethernet driver has changed. Anyone experiencing this isseu? TIA
I contacted this person, he is just a distributor and only serves his own customers. People who have not purchased products from him cannot obtain services from him.
You contact @EllaHomatics on Telegram for beta firmware.
Hello!
I made thise settings so that the Nokia 8010 remote control works on the Homatics box. Now I want to restore it so that it works with the small factory remote control. I deleted the two files (NOKIA and rc_maps.conf) and copied the remote.conf file into the .config folder. Apparently that wasn’t enough.
What else I need to do to make it consider remote.conf and not look for rc_maps.conf?
Does anyone have the firmware flash package for Rocktek GT2 or captured the download address of the update package when getting the update package? Please provide a flash firmware package.
Rocktek should have it, if they want to provide it. Something wrong with you current firmware?
I asked the staff at RockTek and they said they could only mail it for repair and would not provide me with an img image to flash my phone. If you have an img image or an ota upgrade package, can you give me a copy? There is no partition data in my emmc, and there is no need for a brick-saving firmware to boot.
OTA is OTA. Manually you can made that just with burning tool, flash recovery.img method.
But when your vendor not want to give the img file, you cannot made…
Hello dear forum, first of all respect for this absolutely world-class CoreELEC, I love it on my Homatics Box 4K R Plus…
Unfortunately I currently have a problem with certain video files in the lower area of the picture. See photos, I describe it as flickering at the bottom of the picture like on an old VHS cassette, more interestingly the picture problem is only with certain files such as. at this:
Format : Matroska
Format version : Version 4
File size : 8.23 GiB
Duration : 1 h 38 min
Overall bit rate : 11.9 Mb/s
Frame rate : 23.976 FPS
Encoded date : 1970-01-01 00:00:02 UTC
Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 9 2012 15:37:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 9 977 kb/s
Width : 1 920 pixels
Height : 818 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.265
Stream size : 6.72 GiB (82%)
Writing library : x264 core 79 r1352M d487de4
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.1:0.2 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9977 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=2:1.00 / pulldown=0 / nal_hrd=0
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 510 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.04 GiB (13%)
Language : English
Default : No
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate : 448 kb/s
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 316 MiB (4%)
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
flickering at the bottom of the picture ![]()
Interestingly, I don’t have this error when I play this file on my Homatics Box via Android 12 with VLC Kodi or simply via a Blu Ray player… I also tested 3 different HDMI cables and also tried different settings. Unfortunately, this flickering in the lower image area only occurs via CoreELEC on… does anyone have an idea as to what this could be? I have already updated to 20.5, unfortunately the error remains LG Lutz
try Amlogic-no
