No need to apologize, you suggested a possible solution which is the very essence of this forum, helping users ![]()
It seems no answer nor clue where to look will ever come out for this issue so I won’t waste any valuable resource or anyone’s time. To avoid cluttering an already quite long thread, the post will be deleted.
Well for me ethernet worked half the time. Often I had to reboot to get it to work again.
Never got the remote to work even with all the guides from this site.
Also had HDMI handshake issues with audio where there was no audio until a reboot.
Luckily I got the Nokia off Amazon and I returned it as it was just too frustrating an experience. Maybe it will get sorted in the future.
Good afternoon everyone, I’m thinking about buying a homatics 4k r plus with the u sb tuner dvb s2, I can install coreelec, the tvheadend detects the tuner, thank you for your help
Double posting not supported nor is the tuner.
You can use TBS usb tuner with CoreELEC
You can find the necessary information in the forum
I am thinking in the usb tuner from homatics
No and probably never will be.
Tank you all
last update broke DV playback.
You mean 20240429 ?
CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20240429-Generic.img.gz221.32MB2024-04-28 23:13:35
it plays for a few seconds perfectly, but then pauses and the screen goes pink…never happened to me before. EVER.
No problem here, at least with the content I tried with.
yeah no something is definitely wrong…it does not occur with dune’s media player.
It may be wrong something on your device but image itself is fine.
my device works fine.
Like this? Black screen issue on episode change - Help & Support / Operating System - CoreELEC Forums
Something wrong with the builds fix it or i move to the default player
No logs no problem.
Does this tone usually work for you? Argh.
