Homatics Box R 4K Plus
Very surprised that my post to confirm something is solved got flagged as inappropriate ? Strange world it is becoming…
The original post was deleted, please just post what you think it’s fixed and that’s all.
Not really the point, but its fine. Have other stuff to worry about.
no, never…
Hi
Did you manage to solve the problems with your device?
Is the remote control visually different from the previous version v1?
I was thinking about buying the Nokia 8010 because I had read many favorable opinions about it. It seems to work great with Coreelec.
After reading your post, I have doubts whether the Nokia 8010 is a good choice.
Using the latest CoreELEC-Amlogic-ne.aarch64-21.0-Omega-Generic.img.gz I go to Settings > CoreElec > Bluetooth and pair the remote (B21) but none of the buttons do anything. What should I do? I thought it had a local keyboard file included in the latest build.
Try Dune Homatics 4k Plus Infra Red remote config
Copy to Root of CoreELEC
Place in Config Main Folder
Then you will have navigation from ir signal
Then can try ro figure ou Bluetooth
Just a quick response as I managed to get my 8010 remote working with Elec;
I recall having tried 2 version where only 1 worked so lets hope I am now sharing a working version :wink:
alternative keymap for 8010 ir remote
ssh:
systemctl stop kodi
systemctl stop eventlircd
[now copy files] (edit: I did this before but this is how I stored the instructions. Also not sure if a reboot is needed)
  • add file →
    /storage/.config/rc_maps.cfg
  • add folder and file →
    /storage/.config/rc_keymaps/NOKIA
ssh:
ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
systemctl start eventlircd
systemctl start kodi
NOKIA (option 1)
# table NOKIA, type: NEC
0x1d0200 KEY_POWER
0x1d0213 KEY_1
0x1d0212 KEY_2
0x1d0210 KEY_3
0x1d0217 KEY_4
0x1d0216 KEY_5
0x1d0214 KEY_6
0x1d021b KEY_7
0x1d021a KEY_8
0x1d0218 KEY_9
0x1d021e KEY_0
0x1d021f KEY_PREVIOUS
0x1d0202 KEY_NEXT
0x1d0250 KEY_REWIND
0x1d0203 KEY_PLAYPAUSE
0x1d024c KEY_FASTFORWARD
0x1d0201 KEY_STOP
0x1d0241 KEY_MUTE
0x1d0248 KEY_VOLUMEUP
0x1d020b KEY_VOLUMEDOWN
0x1d0204 KEY_CHANNELUP
0x1d0206 KEY_CHANNELDOWN
0x1d025c KEY_HOME
NOKIA (option 2)
0x1d0200 KEY_POWER
0x1d0213 KEY_1
0x1d0212 KEY_2
0x1d0210 KEY_3
0x1d0217 KEY_4
0x1d0216 KEY_5
0x1d0214 KEY_6
0x1d021b KEY_7
0x1d021a KEY_8
0x1d0218 KEY_9
0x1d021e KEY_0
0x1d0202 KEY_NEXT
0x1d0250 KEY_REWIND
0x1d0201 KEY_STOP
0x1d0241 KEY_MUTE
0x1d025c KEY_HOME
0x1d0259 KEY_UP
0x1d0251 KEY_DOWN
0x1d0254 KEY_LEFT
0x1d0215 KEY_RIGHT
0x1d0255 KEY_ENTER
0x1d0219 KEY_BACK
0x1d0209 KEY_MENU
0x1d0211 KEY_CONTEXT_MENU
0x1d0208 KEY_INFO
0x1d021c KEY_EPG
0x1d022e KEY_FAVORITES
0x1d020a KEY_RED
0x1d024d KEY_GREEN
0x1d020e KEY_YELLOW
0x1d020c KEY_BLUE
Hi
I have a Nvidia Shield remote connected by Bluetooth with my Dune Premier Pro (same hardware as the R 4K Plus). It worked fine for a few months but recently I have to remove the remote battery every time I power the box to make the connection. Anyone had the same issue ?
I’m wondering if it’s a hardware failure or a new bug in the nightly builds.
Solved : by enabling standby in CE BT properties for the remote.
is it me or when using
CoreELEC-Amlogic-ne.aarch64-21.1-Omega_nightly_20240522-Generic.img and changing the color depth and the other setting, it does not get updated in the video information page when playing a movie (pressing ‘o’ on the keyboard)… ?
Changes in bit depth (also in subsampling settings) are only applied when you change the refresh rate or resolution.
Strange problem, all of a sudden DV videos play pinkish on my Dune 4k, this never happened before!
I have reset most of settings to no avail!
I also rolled back to Omega stable release!
It plays well on my Android Kodi version and Dune is on the latest Android 12.
Any thoughts?
Edit : Nevermind I got it.
Wtf, how ?
I have used the source device led in DV mode. It does not affect the playback of DV in Andriod.
Bit stuck here…have a rocktek g2 with a b25 remote
can’t get the remote to work at all even when i manage to get it connected none of the buttons work, any idea what i can try?
I just have a question if the Coreelec-ne ce-22 runs on the Homatics Box R4k plus. I tested the Coreelec-no ce-22 and it runs fine, but on the same hardware, after installing the Coreelec-ne ce-22, only the initial logo still spins. Thank you for your response.
Try nightly build 20240613. For me it looks fixed.
EDIT:
Current working solution for Nokia 8010 remote for CoreElec →
