Is Wake on LAN supposed to work universally or does it depend on the device? I’m testing the Suspend feature and so far so good both on USB2 and USB3. I use my TV remote and via CEC, switching the TV to the HDMI connected to the DuneHD Box R wakes it up and everything works fine afterwards without lockups and freezes.
But, now the device is connected to a classic PC monitor at my desk, which obviously does not speak CEC at all, and I’m stuck trying to wake it after suspend. No joy through keyboard/mouse of course as the USB ports are powered off.
From my Linux desktop, using both wakeonlan and etherwake does not lead to a wake up. Any clues?
Does it requires a specially crafted packet to make WOL work properly?
I’ve tested the DuneHD with my old AVR on the Audio side this time and everything works fine except one small caveat.
Stereo and MultiChannel FLAC files I have for my tests work fine. I don’t use Passthrough obviously for these files, so pure PCM is sent over HDMI. My AVR reports the received channels either with the front display, via on screen status display and on screen Information page and 2.0, 5.1 and 7.1 matches perfectly with the source, meaning channels number and sampling frequency.
But, every 4.0 (ie: “quad”, L R Ls Rs) is sent as 5.1 to the AVR as confirmed by every info screen available. Every channel placement is handled correctly with the correct sampling frequency (48/96/192 KHz), there’s just this “phantom” muted center channel, or more precisely, silence data. The same goes for the “phantom” LFE channel, pure silence of course.
NOTE: There’s no difference between “HDMI” and “Multi CH HDMI” for the audio output.
Is this expected, a limitation of the Amlogic SoC or something else? This poses no issue per se but seems a bit weird.
LibreELEC on an old x86 NUC with the same source correctly sends 4 channels with a “quad” (L R Ls Rs) layout to the AVR.
Your message convinced me to give it a try and I ordered the EZ-SP12H21. Unfortunately, it did not gave the results I was expecting. Yes, this time the AVR got the audio from OUT-2 and I had to tweak things a bit. Also, HDR10+ and HLG now work properly because of the HDMI 2.1 in the EZ dongle.
My main complain is of course DolbyVision, which is now exclusively sent as 12 bit 444 in DV-LL format. This is confirmed by CoreELEC info panel (o key) and with the info from here :
Over @ avsforum there is a guide to load custom fw and make your own edid for Ezcoo.
I have loaded a cfw for my Epson ls 12000 projector with lldv 4:2:2
I know, it was already mentioned by kdelaney in post 2327 but I’m not interested at all in DVLL. I have a high end TV which handles DV perfectly, there’s no way I turn to cheaper solutions
And “cheaper” must be taken with a grain of salt as the EZ-12H21 is not what I would call cheap
Yes, that’s enough. If your TV supports it, you can also confirm using extended information in the “Info panel” or whatever it is called in various TV brands.
If you happen to have a modern AVR between CE and your TV, it can also give some useful information. I’ve tested with a Onkyo and it reported all display modes in the on-screen info panel triggered by the “Info” button on the front of the AVR.
Im having local lan transfer speed limited to 100Mbit on my Dune HD. This issue started after RC1 or 2 not sure but it exists on the final Omega release aswell. I can reboot the box and i get 1Gig again but most of the time on the first boot it goes back to 100Mbit with transfer speeds limited around 11Mbps as compare to 115Mbps when 1Gig is recognized. Any idea if the box is initiating wrong Ethernet driver. Can someone with Dune HD variant let me know if you’re experiencing this issue? TIA
Hello all, I have Nokia 8010 (v12.8.3638 with 5.4.242 kernel)
My current issues are:
The crop issue on FHD/HD H264 content you’ve solved - is it now available in the latest nightly build for NE? Both 20/21?
Ethernet is not working under ELEC, I can’t find where this was discussed specifically for Nokia/S905X4-K. I’ve tried both 20.5 (Stable/Nightly) and 21 builds from around 5 April. Was this ever solved too?
Remote - I have the “new” V2 model (RC212) I’ve tried to make it work using IR on ELEC, I followed the forum guide and used the existing keymaps but nothing seems to be working.
I followed this guide using SSH per this post.
All the codes except one (the bottom “Blue” quick-nav) ended with:
’ not recognised, no mapping for scancode 0x041d022e
etc.
Can it be because of the V2, so I should follow the extended guide to “catch” codes one by one using remote to create my own custom keymap?
Thanks for info and all the work you constantly do =)
