Homatics Box R 4K Plus
Thank you very much, it’s running now.
After the manual update to 20240616, Kodi does not start again.
A fresh install doesn’t work either.
I’ve got very strange thing. My box is turn on randomly, and of course after that the box is turn on the TV over CEC. Usually at night and realized it only morning, so half of night is turned on unnecessarily.
This is on the ATV mode does not occur. Any idea?
Thanks!
It should be fixed in 20240620.
Thank you for your response. I did a manual update and everything is ok.
Hi, please is Nokia 8010 supported on CE21 NG with wired network? If so, which dtb should be used? I’m using sc2_s905x4_4g_1gbit.dtb as there is no specific sei dtb. I’m trying to install stable CE21 NG to be able check latest 3D work, but my wired network is not working under CE21 Stable/nightly NG, and wireless stoped working after updating with NG devel version from 3D implementing thread. Thanks.
sc2_s905x4_sei_smb_280.dtb
https://github.com/CoreELEC/CoreELEC/releases/download/21.0-Omega/CoreELEC-Amlogic-ne.aarch64-21.0-Omega-Generic.img.gz
Are we allow to list boxes for sale in this thread?
Is this available for NG? NE has it, but haven’t found it for NG. I guess I can’t use it cross kernel
the Homatics (SEI) boxes were never supported on NG
Thanks. This sums it up pretty conclusively.
It is strange though that it says in the screenshot you pasted “This device is also supported by the Amlogic-ng builds” ?
i think support for NG was dropped, but i could be wrong. any reason why you don’t want to use NE?
It would be great to have this for NG … Maybe I can use it for emuElec…:grin::stuck_out_tongue_winking_eye:
There is a sc2_s905x4_4g_1gbit.dtb in the NG device tree. I did not tried it since I’m using NE myself, but looks like the one to be used when installing NG.
It works, but you have to reboot up to 4-5 times to get ethernet. Sometimes a lot more often… That sucks :disappointed:…
Would be better off with a USB Ethernet Adapter 1Gig
Thats what i used when testing Kinhank G1 on CoreELEC 4.9 kernel
There is no EmuELEC on 5.4.210 kernel?
Need Matrix Kodi?
So, CE 22 is out and we can install it on our boxes, right?
What are the advantages of CE22 vs CE21, or is it too early for us to install it yet?
What about dolby vision, there are no drawbacks with it in CE22 vs CE21?
Also, if we are using CE21 nightlies, it will continue to update only to CE21 nightlies, right? Or there may come a time when developers decide to let CE21 update to CE22 automatically by a nightly?
A lot of questions, I know, just wondering if somenone has some insight about this :slight_smile:
You can install it,but it’s very early alpha stage.
I have a testbox running to be able to identify and report issues. Definately not for daily use as things change very rapidly and issues might arise while solving others.
If you install a major versions far as I know it will only update from that channel/major version.
No DV on CE 22
