https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/207?u=vasco
Input stream adaptiv is installed.
Sorry did you follow the link to the post? There’s an updated version of inpustream helper that the devs launched for test. They didn’t release it yet officially.
i have a ugoos am6b to soundbar to tv, use ng (no DV)
When I open tv(soundbar) 1st , am6b 2nd, playback some hdr there is no signal, when stop the signal back.
But when I open am6b 1st , tv(soundbar) 2nd,all works well, maybe you can try
Btw, in settings, force coulor scamping in 4:2:2 in wiki may fix it, but I don’t know how it works with DV
Make sure you have installed latest nightly, i had Widevine installed on it but atm Netflix is up to 1080p (no DV) and Disney+ 720p (no (DV)
Oh man… Shame on me … I found the zip and it works … Sometimes I’m blind… Thx
Yes, its limitation of system.
Hardware decoding not possible, thats the reason.
I knew it, i only share my solution with avr or soundbar no signal issues.
Does ethernet works for all with today build 20230418 ?
yes no problem
Hi, I’m not at home, I’ll be able to test the ethernet in a week.
Yes , Sir… It works flawlessly… Box: Dune HD homatics R4k+ …
Btw… Nice support here thx …
Dumb question. Received my Dune HD homatics R4k+ yesterday. Purchased it for the “Dune” app.
Since it does not have a microSD card slot, is everyone using a USB 3 pen drive? Also, which firmware do I use?
thanks
The “greenish” picture on player led 422 used should be fixed with tomorrow nightly 20230419.
Just set everything to auto and don’t force 422 mode.
I’m using a SanDisk USB3 SD card adaptor in the blue USB3 slot.
The right one in front…
Thank you. Which build are you using?
The latest CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20230418-Generic.img.gz
I can’t get IPTV simple client to work. Now I can install everything (I have installed inputstream.rtmp from vpeter), but when I enter live TV, I get a message on the top right of “the PVR manager is starting” and it never finishes starting. I am using emby for kodi next gen 8.1.2 for iptv, I have it on PC with kodi and everything works perfectly.
I am attaching the latest log file which is inside the Logfiles folder. I don’t know if you need anything else. Very thanks for your help and work!!
log-2023-04-18-17.58.07.zip (130.9 KB)
Do you even have iptv simple addon configured correctly? I don’t think so because of
AddOnLog: pvr.iptvsimple: pvr.iptvsimple - LoadPlayList - Playlist file path is not configured. Channels not loaded.
