Homatics version of Kodi is under android. CoreELEC is its own OS. Did you try the power saving menu? I also set my box like this
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/278?u=rome1931
I did try the power save menu but no good result. I would like to try the hack you pointed to but its a bit beyond me. I have ssh into my machine before to add keymaps but I had much clearer instructions for that. The way this is written assumes you know what your doing when in fact I don’t ![]()
That’s not going to work, because we make changes to both Kodi and the kernel to make things work correctly. In addition, Android uses a completely different video pipeline, so it wouldn’t really work regardless.
LOL I figured it was too good to be possible or someone would have done it already.
It’s mostly copy/paste in the terminal and instead of vi to edit config file, use nano.
Nothing was changed in this area. And about what numbers you are talking about (5 and 10)? Where do you set this in CE (because I’m not familiar with them)?
The brightness in CE has values from 0 (LED off) to 4 which is max brightness. It is set by command in terminal
echo 1 >/sys/devices/platform/soc/fe000000.apb4/fe06c000.i2c/i2c-3/3-003c/leds/bct3236/brightness
and checked by command
cat /sys/devices/platform/soc/fe000000.apb4/fe06c000.i2c/i2c-3/3-003c/leds/bct3236/brightness
But this brightness is little confusing because when we set the color we also set the intensity of it.
Which consecutive set also brightness of the LED.
Color is set in DTB but also from terminal with command
echo 101010 >/sys/devices/platform/soc/fe000000.apb4/fe06c000.i2c/i2c-3/3-003c/leds/bct3236/edge_color_on
where 101010 is the default blue color.
This 101010 is represented as RRGGBB (red, green, blue) and we set the intensity of separate RGB LED. Values are in HEX form from 00 to FF.
00 is off, FF is maximal intensity.
Beside setting color for edge_color_on there ais also edge_color_off and edge_color_suspend.
You can add echo line to autostart.sh to fix your issue but I checked last nightly build and value is still 1 for me.
Would be good to understand what went wrong for you.
I’m running into the following with the (black) B21 remote over Bluetooth on a Dune HBR4K+:
Otherwise, this seems like a great little remote to be able to use with CoreELEC.
Thats mean you can use the homatics in IR mode, in coreelec, with the remote. conf, and wake up and power off working? Cool.
My ir diodes still in transit… ![]()
Could you clarify how this addresses what I had mentioned?
I use this remote.conf file on my DuneHD Homatics. It works fine with original B21 remote control in IR.
I bought a Nokia rc110 remote control (original remote control of Nokia 8010 box)
I tested it with my DuneHD Homatics box in IR. It didn’t work.
Can you send me the right remote.conf of Nokia remote control?
Or what do I wrong? How should i do right?
Does anyone have Power and Volume working over Bluetooth with the B21 remote (and controlling CEC devices)? This is ideally what I’m looking for since IR doesn’t seem necessary in my setup if given that Bluetooth has less latency and doesn’t need line-of-sight.
My Homatics uses my old Minix RF remote with its USB RF dongle without any re-programming of keys.
It does not pass-through Dolby Atmos TrueHD to my Denon AVR.
It get remote paired without going to go under Settings > CoreELEC > Bluetooth and reconnect it. At least it works for me and maybe it will work for you too.
Well, I think I was too fast with this answer (with too little thinking). Because on suspend USB port loses power the USB stick get remounted as different device. I’m still investigating the “proper” solution for this. Or maybe Homatics could do some change in Android to keep power on USB for suspend.
Which means only powering on from off state is supported.
Update: Maybe I do have a working solution. But storage must be used from eMMC with my instructions above.
Thats enough for me ![]()
btw. which one diode soldered? CHQ1838 or VS1838B IR diode
I just took one 38kHz IR receiver diode from one old project (TSOP38238).
I am right now testing a new item that a user EDID can be used
This is a good feature, is there any progress?
Hi, I was long time out. Please last time I ised image with lan problem solved but dont have now nothing updates. So may question is is new nigthly ce21 version without lan network issues? Thank you this version image I have now installed
21.0-Omega_devel_vpeter
Why don’t you update and check yourself? And you will see probably it is solved. But only you can confirm that.
