Maybe because your internet connection is only 500MBit/s ![]()
Try with iperf on LAN.
Iperf with lan not possible here. Since I got vontar I’ve moved all server stuff to it ![]()
One device for all ![]()
Interesting thing is I set up friend same vontar but bought in China… Arrived pretty quick… He’s box is able to reach 800mbps.its defo 1gbps connection…
As you said in other posts. It’s probably cheap components they use to build it…
That’s why I’m interested what homatics can do…
Under Android TV I get +900Mbit up/down by LAN with the Homatics R Plus. The same results I get when comparing it with my Shield TV Pro (2019 model).
Can you try this with CE?
curl -s https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py | python -
Hooorayyy it worked ![]()
reading is a challenge tho ^^
the important part is to keep holding the reset even after the recovery is loaded ![]()
that could be made clearer xD
PS: can we maybe put the correct reset method and the hint that you need to hold even if menu appears into the first post?
Bump , Can someone tell me please ?
i dont know what lldv is.
but there are options to for hdr->sdr and vise versa.
i also saw tonemapping options in the settings.
regarding DV the latest announcement said it is in eraly stages so i guess it will be able in the future?
The easiest way for first boot into coreELEC is the method without the reset button…
You only have to enable adb debugging in developer settings und use the command “reboot update” with your cellphone and the app remote ADB shell … That’s it …
You can set it to LLDV, we don’t support SDR/HDR to DV conversion.
Or just hold reset. Much easier than downloading an app, etc.
Didn’t you ask in the Telegram group? I already answered you there, yes it can be done with LLDV.
No one here with 1gbps internet? ![]()
What are you doing that you need the box to saturate a gig connection?
Using rtorrent, qbittorrent, also serving my content with emby server to family members. Have swag docker service running in background which is serving my sat tuner outside of home network. Is that enough to have fully working speed I pay for? ![]()
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec receiver
[ 5] 0.00-10.00 sec 1.09 GBytes 937 Mbits/sec 0 sender
No problem with saturating a 1 gig connection with the R-4K, whatever you do with it will probably be limited by the SoC and/or other system bottlenecks.
Thank you!
How about python speedtest?
Download: 649.10 Mbit/s
Upload: 109.37 Mbit/s
1000/100m connection
Might be a limitation of the servers it’s testing against, doesn’t seem too bad.
Maybe it’s python thing? Normal speedtest with web browser always gives me full speed. Testing in android also have full speed. It’s ce what I can’t pass 500…
Nope, not me . But thanks for answer now .
But no sdr/hdr to lldv was said above
Anyone had any choppiness in DV/HDR10+ content?
