Nothing to fix because this feature is not supported anyway.
Try with CEC disabled (maybe it interfere somehow).
from whom?
Homatics?
Android?
CE?
We are doing CE. So guess which one.
And you know what? I just checked on my device and is still working for me. So it is something with your setup (TV, amplifier, …).
oh ok (:
i thought that maybe the device is not supporting this feature (:
It only works if you have CE storage on emmc.
What do you mean? Whitch function?
Sleep/resume
Can you explain this to me? Do I understand correctly that you are talking about uploading CE to internal memory? If so, how does it relate to android tv?
So what are these issues with Kodi Omega that mentioned in the announcement? Can somebody please elaborate?
rome1931
Thank you for your answer.
There is a major issue with how ffmpeg 5/6 were merged in without addressing core changes that should have be made at the same. Notably PVR resume is failing but I am sure there are other issues.
I used the following procedure:
Create a file with the content provided in my last comment and name it NOKIA.
Use Filezilla and copy this file in /storage/.config/rc_keymaps/ on the device.
Create a file named rc_maps.cfg with the following content:
meson-ir * NOKIA
Use Filezilla and copy this file in /storage/.config/ on the device.
Open SSH connexion to the device and:
systemctl stop kodi
systemctl stop eventlircd
ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
systemctl start eventlircd
systemctl start kodi
Enjoy, hope this will work for you.
Just copy the file and reboot - no need for all those ssh commands.
Hello vpeter, thanks for the info ![]()
rome1931
Everything works.
got my homatics box yesterday and now trying to boot coreelec.
However I am unable to boot coreelec.
USB stick create commands:
dd bs=1M conv=fsync if=./CoreELEC-Amlogic-ne.aarch64-20.3-Nexus_nightly_20230729-Generic.img of=/dev/sdb
cp sc2_s905x4_4g_1gbit.dtb …/dtb.img
Pressing reset when plugging in power gets me to boot screen which says.
Fastboot
Press RESET again to enter Recovery mode.
Have tried 2 different USB sticks. ANyone has any idea what can be wrong?
Wrong dtb. Try proper one
sc2_s905x4_4g_1gbit
Which is the proper one then ?
s4_s905w2_2g.dtb
s4_s905w2_4g.dtb
s4_s905y4_2g.dtb
s4_s905y4_4g.dtb
s4_s905y4_buzztv_hd5.dtb
s4_s905y4_khadas_vim1s.dtb
sc2_s905x4_2g_1gbit.dtb
sc2_s905x4_2g.dtb
sc2_s905x4_4g.dtb
sc2_s905x4_buzztv_u5_4g_1gbit.dtb
sc2_s905x4_buzztv_x5.dtb
sc2_s905x4_sei_smb_280.dtb
sc2_s905x4_ugoos_am7.dtb
sc2_s905x4_ugoos_x4.dtb
t7_a311d2_beelink_gt_king_ii.dtb
t7_a311d2_khadas_vim4.dtb
EDIT: Tried sc2_s905x4_sei_smb_280.dtb aswell, but same issue.
