Also I guess, because no log was included, you had a ceemmc install. As the pop up message tell you need to flash Android again to restore the super partition.
It’s a requirement for CE-21.
No, there is not possible to make any on android partition with this box. That was just simple install on the pendrive, then come this popup.
The dmesg from other users shows clear a super partition. But again, you did not include any log so we are not able to help you.
Ok, I will trying to show log tomorrow.
dmesg
http://ix.io/4rsL
blkid
http://ix.io/4rsM
kodi
http://ix.io/4rsN
Please also journalctl -l | paste
journalctl
http://ix.io/4rth
And fw_printenv | paste please
fw_printenv
http://ix.io/4rtk
Thx, we have now hardcoded slot _a but this device do not use it. We will need to adjust the script for loading the tee stuff.
Thanks @rome1931.for the logs.
Just one question @Portisch , if the installing ce21 in the Homatics would be successful, thats won’t it interfere with android fw updates, because of the super partition?
I am a beta tester in homatics group and there is no option to flash back android fw, the beta updates come from ota directly.
If you want dual boot you need to run CE from USB/SD.
Installing CE on eMMC partially destroys Android which doesn’t run anymore.
Ok I tried installing CE21 NE on my homatics box r Plus on the beta firmware v4474 and I can’t get ethernet working. I did go and enter CE settings - hardware and change Motorcomm option to assembled . After a reboot eth still not working.
Does anyone know if the Dune HD Homatics Box R 4K variation Dune HD Homatics Box R 4K Plus will be potentially able to run CE?
I asked in the telegram the other day and I was told yes.
I did run Amlogic-ne.arm-20.1-Nexus_nightly_20230317-Generic on the Dune version, all worked (OS build 3660). As it did with the beta firmware 4474 on the Homatics version.
With kernel 5.4.125 I was able to keep the box runnning 24/7 but on 5.4.180 the get a blank screen if I turn tv back on after it was off for a while. I have to reboot to get gui again.
dmesg
http://ix.io/4s40
I see same here. I guess it’s this hdmitx: current hpd_state0, exit set_disp_mode_auto
Hi Portisch,
I am having trouble with LAN on one of the 2 Box R 4K Plus devices when cold booting into CoreELEC and I am not sure what is causing it. With one of the box I cannot get LAN to work on cold boot to CoreELEC bit it will work if I boot into ATV and then reboot into CoreELEC. The other Box R 4K has no issue with LAN when cold booting. I have also seen similar issues with other members on Homatic forum. Can you please help.
I am using CE21 NE nightly build. Can supply dmesg for the 2 devices.
It runs but no Ethernet on Kodi 21.
