Homatics Box R 4K Plus
I am happy to provide you the file from my Nokia if this helps
I would give it a try. Don’t think I will irreversably damage something here :wink:
You got any possibility to upload that file?
Upload to an empty Google Drive folder?
Would be deleted right after…
I would be really interested on that file too. I got the same response from the team behind Nokia 8010 :frowning:
Should be there now :slight_smile:
Thank you so much.
It will be there for 15 more minutes.
Thank you very much!!
OMG @Adam86 thank you very much. DV remuxes are working flawlessly!
I have tried some Full UHD ISO with DV ripped from my discs, and in this case, they are seen only as HDR. Are DV for UHD iso still not supported? Is there some extra configuration for this that need to be done?
Thank you!
Dune HD Homatics Box R 4K Plus NOT allowing TV to turn off.
Had issues with previous install, so did a complete re-install (20.3 Nexus nightly 20230908) several days ago. Each day, I added a few different locations for my media. Everything went well untill last night, this morning my TV was turned back on. No matter what I do, IF CE is running, my TV turns back on almost imediately after turning it off with the TV remote.
I have had this issue before with a differnt device, but it “cured” itself…
At this time I have two options, remove power from the TV or power off the Dune media player. Neither of these options are acceptable.
Will logs help solve this issue?? Or should I do another re-install, and should I use a different version of CE.
thanks
Cool. My dune homatics version just not power off. When I try to power off from remote, or from menu, the box just reboot itself.
Just help when I unplug the power cord.
I don’t have that issue with my Dune.
My problem is that I keep my Dune “running” all the time with CE. Now, when I turn off the TV with the Dune powered on, the TV will turn itself back on, almost instantly.
I can power on and off my Dune using the IR portion of the stock remote.
Edit: To test your issue, I used my remote to power off my Dune, and it stayed off. After a few minutes, I powered my Dune back on using the remote and it powered on as expected.
I then, with the Dune still powered on, I turned off the TV and IT STAYED OFF!! It fixed itself…
It’s possible the device do some “key press” by itself.
This happen because there is a floating analog input what can cause on certain level different key press.
Open a SSH connection and try this;
mf
cd /flash
fdtput -t s dtb.img /adc_keypad status disabled
sync
reboot
Then observe if it might solve your issue.
I have cec off in the CE. When I try to off the box, from 10 to 8 rebooted imediately. Sometimes power off normal. I need to check, I have 3 different CE installation, different nightlys.
Earlier today, the problem seemed to “fix” itself.
I went ahead and ran your script using Putty, and the TV DOES stay off.
thanks.
Where are the CEC settings in CE?
https://kodi.wiki/view/CEC
That is a lot of reading, but thank you. I prefer to NOT use the CEC function on any of my devices.
Hi everyone! Thank you for the guide! I followed it and CoreELEC is up and running on my Nokia 8010. Awesome software!
Currently only have two issues:
  • Is it possible to start up CoreELEC using the remote after shutting it down from the menu? I followed up Nokia 8010 remote instructions, every button works but I can’t start it up. Currently the only way to start it again is pulling the cable out and in again.
  • Does DV work for Full UHD ISO? On remuxes it works flawlessly but full UHD ISO fallback to HDR only.
If possible, I would also like to have the updated dovi.ko for my Nokia 8010 box.
Do you have a Google Drive that I can place it on for you?
