Homatics Box R 4K Plus
Thank you very much.
There you go, hope that helps.
If u have the choice, for you what is the best s905x4 for coreelec ? Dune ? Homatics ? Nokia ? And why ?
i don’t want an ATV player the Android layer make me seek … So nvidia Shiled is not an option …
Actually I have a beelink GT1 but some of my mkv files are not supported
Thanks a lot
They are all the same with the the exception of the ir sensor. Some have it and some don’t.
Some have ethernet issue no ?
All boxes work as intended
Firmware introduction:
Hello, the CoreELEC system optimization is more perfect, please refer to it, thank you.The firmware is on Google Drive.
link se:
https://drive.google.com/u/1/uc?id=1cc1AIhe4SwdX5ygEvrUdQz2sg1hGEFcb&export=download
Dune has an IrDA sensonr and one extra partition with Dune software player that can play (I think DV) .iso images on your network. As seen above, Homatics/Dune are also one development step forward with the latest Android build.
I bought Dune and I am happy with it. CE works great on it.
It’s up to you whether an extra $20 is worth it or not. I guess Dune software license is something where you can spend a little more.
blueyeti2023, if you provide some images you should at least give some description what they are.
Hello, the firmware I shared, I hope you can also brush the firmware I shared, test it, I hope you can do the same as his firmware optimization, basically do not need to move, as long as the corresponding dtb file can be. I’m in trouble.
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/1804?u=blueyeti2023
Where are the sources for this image? I would say nowhere?
Why you are in trouble?
Come on, that’s it! Please maintain and update according to your schedule. By the way, I hope the s928x equipment can be used as soon as possible.
I’ll put you on analysis for a permanent ban. This is not your business nor this is run by you.
understand.
I don’t remember the last time we had to act on an user because apart from normal forum interchanges this is the first time in many years we have someone so disrespectful with the work done voluntarily by our devs. This crosses a line. This is a small suspension to allow the user to think on its actions. It will become permanent if the tone doesn’t change.
Little off-topic:
Someone know if Homatics Box R 4K ( not Plus) cheap little brother work well with USB 3.0/1gbps adapter? I not need DV for second TV.
Thanks.
I have the lite model and can run a test for you. Maybe tonight.
I need some help please
I need some help please with dovi. ko
posts like these are useless. explain what is your issue, then people might help.
