Chris, do you have a Google Drive link you can put on here? I’ll put it on there and then if you remove straight after.
I can’t actually PM on here either and have been a long time member.
Hello, everyone,
We are excited to announce the release of the first beta version of ATV12 today. We want to express our gratitude to all our alpha testers for their valuable feedback.
If you are interested in testing ATV12, please feel free to contact me privately and provide your device’s serial number.
Important notes:
1.After the ATV12 update, CoreELEC will no longer support Dolby Vision display.
2.Once you update to ATV12, it is not possible to revert to ATV11 or any previous versions.To ensure a smooth transition and identify any potential issues, we recommend that individuals with more than one 4K Plus box be the first to test the new version.
@EllaHomatics
Not good news!
ATV12 breaks CE DV?
Working now.
vpeter added a patch for it.
Nice!
How?
So we can update to ATV12 and then update to CE latest nightly?
BTW how does ATV 12 perform on the homatics?
Its first public ATV12 beta. You can test and ask in Homatics beta test telegram group.
There you go, file is now there ![]()
Thank you very much!
is anybody here struggling with heat? mine gets up to 165f and it makes me uncomfortable. Is there any modifications I can do or improve the heat spreader?
The latest changelog includes the led configuration add on for dune devices.
How do we find and use this addon?
It will be under Programs in CoreELEC repository. But it was not yet build.
How to use? Try and see (it comes without instructions).
So if it was not built yet, we have to wait for another nightly to try it?
Or probably we have to wait for a “homatics-leds” to appear in the list of available addons to install in addons > CoreELEC add-ons > services
Right? ![]()
Mecool has entered the game with it’s newest Dolby Vision player. It does have a microSD card slot, Guessing it is the same as the other based Homatics box.
I feel like this should be quite intuitive…
But, how do we do this?
without downloading the addon externally and copying the file to the device
I think the addon will be available very soon, you will set this effect, or lot of solid color, or you can set just some led to light in active mode. Very cool thing. ![]()
