How to configure VFD
Hello all!
I have a question.
Does OpenVFD service also control the On/Standby LEDs of the TV Box?
I have a Vontar X3 TV Box. As already suggested in the thread, I used the config from HK1 X3 and VFD itself works fine, except for the On/Standby LEDs. They are swapped (It is “Red” when CE is running and “Blue” when it is switched off).
The native Android firmware however lights it correctly: Red in standby and Blue when it is on.
Any ideas on how can I correct this behavior?
This is most likely a DTB thing, OpenVFD doesn’t control the box’s LEDs.
Is there any link where I can read more about dtb ?
What is a device tree
How to extract a device tree
I understand it’s not the best place to ask it, if you point where should I will ask there, but:
is
	gpioleds {
		compatible = "gpio-leds";
		status = "okay";
		sys_led {
			label = "sys_led";
			gpios = <0x45 0x0b 0x01>;
			linux,default-trigger = "default-on";
what I am looking for?
EDIT: Solved. For anyone looking for a solution here is it
I’m a newbie in this forum and would like to ask for help configuring the vfd.
I bought an X96 android box with S905X4 and I want to use it with CoreELEC, but I can’t get the vfd to work.
The cat /sys/kernel/debug/gpio output from Android 11: https://pastebin.com/U96SsFxm
I also found this file in the android kernel:
https://android.googlesource.com/kernel/arm64/+/f5269100977385d1fd4a5ef68e49631892cf4fe4/include/dt-bindings/gpio/meson-sc2-gpio.h
I opened the box and there is AiP1628 chip and type “3” display in it.
Based on this information I created a new vfd.conf file with the following lines:
vfd_gpio_clk=‘0,0,0x00’
vfd_gpio_dat=‘0,1,0x00’
vfd_gpio_stb=‘0,39,0x00’
vfd_chars=‘4,3,2,1,0’
vfd_dot_bits=‘0,1,2,3,4,5,6’
vfd_display_type=‘0x03,0x00,0x00,0x00’
But no luck, the display remained dark.
The box is with 4/64GB memory and 1000Mbps Ethernet port: https://imgaz.staticbg.com/thumb/large/oaupload/banggood/images/29/B9/199920bc-cd4c-464c-bf0c-18dcb97b34d0.jpg.webp
(Sorry for the two posts, but as a new user I can only put two links in one post.)
You need to install the latest nightly build.
Then try this vfd.conf. I think that the icons are not correct, but you should get the time.
x96-max-ultra-vfd.conf (1.2 KB)
If icons are wrong, you’ll have to play with vfd_dot_bits or you can do that with the openvfd service in kodi.
Please let me know what the correct config for the dot bits is.
First of all, thank you for your quick help. It was an inattention that I mixed up the data and the clock in the configuration.
I’m a bit stuck again with the configuration. I found the values:
USB=0, Card=1, High Wifi=2, Low Wifi=3, Col=4, Apps=5, LAN=6, N/A=7
Neither display type 2 nor 3 is not show all the possible values. Only display type 3 can handle both Low Wifi and High Wifi icons at the same time.
I have checked the source code and there is no behavior required for this display.
https://github.com/arthur-liberman/linux_openvfd/blob/master/driver/controllers/fd628.c
Best results so far (depending on which icons you prefer to see):
vfd_dot_bits=‘7,7,7,6,4,2,3’
vfd_display_type=‘0x03,0x00,0x01,0x00’
or
vfd_dot_bits=‘5,7,0,1,4,7,7’
vfd_display_type=‘0x02,0x00,0x01,0x00’
Any idea?
you have activated the time on the display at X96x4
Does OpenVFD run in Coreelec-ne ? I installed it but I don’t see /usr/lib/systemd/system/openvfd.service and there is no dmesg output.
Edit: it is working with the current version.
VFD for X96 x4?
Hello my device is S905x3 4gb ram /32 rom I put x96air rom on the device, the front led does not work, can you help me?
dmesg
Bluetooth: Out-of-order packet arrived (1 != 0)
[ 17.556795@3]- Registered IR keymap rc-empty
[ 17.557080@3]- input: meson-ir as /devices/platform/ff808040.meson-ir/rc/rc0/input7
[ 17.557305@3]- rc rc0: meson-ir as /devices/platform/ff808040.meson-ir/rc/rc0[ 17.558615@0]- meson-ir ff808040.meson-ir: AO_RTI_PIN_MUX : 0x110011
[ 17.558629@0]- meson-ir ff808040.meson-ir: receiver initialized
[ 17.568303@3]- lirc_dev: IR Remote Control driver registered, major 496
[ 17.574894@3]- rc rc0: lirc_dev: driver ir-lirc-codec (meson-ir) registered at minor = 0
[ 17.574903@3]- IR LIRC bridge handler initialized
[ 17.687427@0]- IR NEC protocol handler initialized
[ 17.691852@3]- OpenVFD: Version: V1.4.1
[ 17.692958@3]- OpenVFD: vfd_gpio_clk: #0 = 0x00; #1 = 0x41; #2 = 0x00;
[ 17.692961@3]- OpenVFD: vfd_gpio_dat: #0 = 0x00; #1 = 0x40; #2 = 0x00;
[ 17.692964@3]- OpenVFD: vfd_gpio_stb: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 17.692967@3]- OpenVFD: vfd_gpio0: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 17.692970@3]- OpenVFD: vfd_gpio1: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 17.692973@3]- OpenVFD: vfd_gpio2: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 17.692975@3]- OpenVFD: vfd_gpio3: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 17.692977@3]- OpenVFD: vfd_gpio_protocol: #0 = 0x00; #1 = 0x00;
[ 17.692981@3]- OpenVFD: vfd_chars: #0 = 0x00; #1 = 0x04; #2 = 0x03; #3 = 0x02; #4 = 0x01;
[ 17.692986@3]- OpenVFD: vfd_dot_bits: #0 = 0x00; #1 = 0x01; #2 = 0x03; #3 = 0x02; #4 = 0x04; #5 = 0x05; #6 = 0x06;
[ 17.692989@3]- OpenVFD: vfd_display_type: #0 = 0x00; #1 = 0x00; #2 = 0x00; #3 = 0x06;
[ 17.692993@3]- OpenVFD: Detected gpio chips: periphs-banks, aobus-banks.
[ 17.692999@3]- OpenVFD: “periphs-banks” chip found. base = 410, pin count =
86, pin = 65, offset = 475
[ 17.693001@3]- OpenVFD: “periphs-banks” chip found. base = 410, pin count =
86, pin = 64, offset = 474
[ 17.693002@3]- OpenVFD: Skipping vfd_gpio_stb evaluation (0xFF)
[ 17.693004@3]- OpenVFD: Skipping vfd_gpio0 evaluation (0xFF)
[ 17.693005@3]- OpenVFD: Skipping vfd_gpio1 evaluation (0xFF)
[ 17.693006@3]- OpenVFD: Skipping vfd_gpio2 evaluation (0xFF)
[ 17.693007@3]- OpenVFD: Skipping vfd_gpio3 evaluation (0xFF)
[ 17.694179@3]- OpenVFD: Select FD6551 controller
[ 17.694249@3]- OpenVFD: SW I2C interface intialized (address = 0x0000 (
canvas.idx =0x42
[ 21.678392@3]- fb: osd[3] canvas.addr=0xed600000
[ 21.678394@3]- fb: osd[3] canvas.width=128
[ 21.678395@3]- fb: osd[3] canvas.height=32
[ 21.678396@3]- fb: osd[3] frame.width=32
[ 21.678397@3]- fb: osd[3] frame.height=32
[ 21.678398@3]- fb: osd[3] out_addr_id =0x4
[ 36.428548@3]- cectx ff80023c.aocec: CEC framework ctrl enabled
[ 37.254355@3]- OpenVFD: Select FD628 controller
[ 37.254643@3]- OpenVFD: SW SPI 3-wire interface failed to intialize. Invalid
CLK (475), DAT (474) or STB (-2) pins
[ 37.254646@3]- OpenVFD: Failed to initialize the controller, reverting to
FD6551
openvfd.service - OpenVFD Service
Loaded: loaded (/usr/lib/systemd/system/openvfd.service; disabled; vendor p Active: active (running) since Tue 2022-10-04 06:43:24 UTC; 2h 4min ago
Main PID: 4080 (openvfd-start)
Tasks: 4 (limit: 3722)
Memory: 1.4M
CGroup: /system.slice/openvfd.service
├─4080 /bin/sh /usr/lib/coreelec/openvfd-start
└─4127 /usr/sbin/OpenVFDService
Oct 04 06:43:24 CoreELEC systemd[1]: Started OpenVFD Service.
CoreELEC:~ # cat /sys/kernel/debug/gpio
gpiochip1: GPIOs 410-495, parent: platform/pinctrl@ff634480, periphs-banks:
gpio-448 ( |amlsd ) out hi
gpio-458 ( |amlsd ) in hi
gpio-474 ( |openvfd ) in hi
gpio-475 ( |openvfd ) in hi
gpio-482 ( |sdio_wifi ) out hi
gpio-483 ( |sdio_wifi ) in hi
gpio-493 ( |bt_rfkill ) out hi
gpio-495 ( |bt_rfkill ) out hi
gpiochip0: GPIOs 496-511, parent: platform/pinctrl@ff800014, aobus-banks:
gpio-498 ( |avout_mute ) out hi
gpio-499 ( |key ) in hi
gpio-507 ( |? ) out lo
CoreELEC:~ #
I will need cat /sys/kernel/debug/gpio from Android, not from CoreELEC.
Also, what’s the full name of the device?
Try this config
https://raw.githubusercontent.com/arthur-liberman/vfd-configurations/master/x99-max-plus-x88pro-x3-vfd.conf
