How to configure VFD
What I am observing is the following.
systemctl status openvfd.service
× openvfd.service - OpenVFD Service
Loaded: loaded (/usr/lib/systemd/system/openvfd.service; disabled; preset:
Active: failed (Result: exit-code) since Thu 2023-02-16 23:40:59 IST; 1min
Duration: 366ms
Process: 3330 ExecStart=/usr/lib/coreelec/openvfd-start (code=exited, status
Process: 3388 ExecStopPost=/usr/sbin/rmmod openvfd (code=exited, status=0/SU
Main PID: 3330 (code=exited, status=1/FAILURE)
 cat /sys/kernel/debug/gpio
CoreELEC:~ # cat /sys/kernel/debug/gpio
gpiochip1: GPIOs 410-495, parent: platform/pinctrl@ff634480, periphs-banks:
 gpio-448 (                    |amlsd               ) out hi
 gpio-458 (                    |amlsd               ) in  lo
 gpio-482 (                    |sdio_wifi           ) out hi
 gpio-483 (                    |sdio_wifi           ) in  hi
 gpio-493 (                    |bt_rfkill           ) out hi
 gpio-495 (                    |bt_rfkill           ) out hi
gpiochip0: GPIOs 496-511, parent: platform/pinctrl@ff800014, aobus-banks:
 gpio-498 (                    |avout_mute          ) out hi
 gpio-499 (                    |key                 ) in  hi
 gpio-507 (                    |?                   ) out lo
The vfd.conf file updated with vfd_gpio_dat=‘1,10,0x10’ and any value other than vfd_gpio_clk=‘1,11,0x10’ keep the openvfd service in running status. If these values are interchanged or modified then openvfd service fails.
Example: Below given keep the openvfd service in running status however the values are showing as in hi and in lo instead of out hi which is expected behaviour to keep the VFD on. I am unable to update the vfd.conf with the value 11. If I do that then the service is failing.
vfd_gpio_clk='1,12,0x10'
vfd_gpio_dat='1,10,0x10'
vfd_gpio_stb='0,0,0xFF'
     Active: active (running) since Thu 2023-02-16 23:44:57 IST; 3min 40s ago
   Main PID: 4122 (openvfd-start)
      Tasks: 4 (limit: 3724)
     Memory: 1.0M
     CGroup: /system.slice/openvfd.service
             ├─4122 /bin/sh /usr/lib/coreelec/openvfd-start
             └─4137 /usr/sbin/OpenVFDService -s CE20
Feb 16 23:44:57 CoreELEC systemd[1]: Started openvfd.service.
 gpio-506 (                    |openvfd             ) in  hi
 gpio-508 (                    |openvfd             ) in  lo
I looked at the dmesg you posted again and when you created it you were not using the trident vfd.conf.
Set the vfd.conf to the values to the original trident config. Then reboot, and then generate the dmesg file.
Original vfd.conf (trident):
This file must be renamed to vfd.conf and placed in the /storage/.config/ folder.
Trident T527 (S905X3) configuration
#gpio_xxx:
[0] 0 = &gpio, 1 = &gpio_ao.
[1] pin number - https://github.com/openSUSE/kernel/blob/master/include/dt-bindings/gpio/meson-g12a-gp>
[0] Reserved - must be 0.
vfd_gpio_clk=‘1,11,0’
vfd_gpio_dat=‘1,10,0’
vfd_gpio_stb=‘0,0,0xFF’
#chars:
< DHHMM > Order of display chars (D=dots, represented by a single char)
vfd_chars=‘4,3,2,1,0’
#dot_bits:
Order of dot bits. Typical configurations:
Display Type 0, 1 usually has Alarm, USB, Play, Pause, Col, Ethernet, Wifi dots
Alarm = 0, USB = 1, Play = 2, Pause = 3, Col = 4, Eth = 5, Wifi = 6
Display Type 2 usually has APPS, USB, SETUP, CARD, Col, HDMI, CVBS dots
APPS = 0, USB = 1, SETUP = 2, CARD = 3, Col = 4, HDMI = 5, CVBS = 6
Display Type 3 Power, LAN, Col, Low Wifi, High Wifi
N/A = 0, N/A = 1, Power = 2, LAN = 3, Col = 4, Low Wifi = 5, High Wifi = 6
vfd_dot_bits=‘5,6,2,3,4,0,1’
#display_type:
[0] - Display type.
[1] - Reserved - must be 0..
[2] - Flags. (bit 0 = ‘1’ - Common Anode display)
[3] - Controller.
vfd_display_type=‘0x01,0x00,0x00,0x06’
Active: failed (Result: exit-code) since Tue 2024-02-27 22:56:08 IST; 3min
Duration: 646ms
Process: 3478 ExecStart=/usr/lib/coreelec/openvfd-start (code=exited, status
Process: 3585 ExecStopPost=/usr/sbin/rmmod openvfd (code=exited, status=0/SU
Main PID: 3478 (code=exited, status=1/FAILURE)
Feb 27 22:56:07 s905x3anbx systemd[1]: Started openvfd.service.
Feb 27 22:56:07 s905x3anbx openvfd-start[3559]: Open device failed.
Feb 27 22:56:07 s905x3anbx openvfd-start[3559]: : No such file or directory
Feb 27 22:56:07 s905x3anbx systemd[1]: openvfd.service: Main process exited, cod
Feb 27 22:56:08 s905x3anbx systemd[1]: openvfd.service: Failed with result 'exit
dmesg:
dmesg.log (72.1 KB)
Use systemctl status openvfd.service --no-pager
After service is started check for any errors with journalctl -l --no-pager
I could find below given wrt to openvfd. I am attaching the complete log as well here.
journal.log (126.5 KB)
s905x3anbx:~ # systemctl status openvfd.service --no-pager
Loaded: loaded (/usr/lib/systemd/system/openvfd.service; disabled; preset: disabled)
Active: failed (Result: exit-code) since Tue 2024-02-27 22:56:07 IST; 48s ago
Duration: 650ms
Process: 3466 ExecStart=/usr/lib/coreelec/openvfd-start (code=exited, status=1/FAILURE)
Process: 3571 ExecStopPost=/usr/sbin/rmmod openvfd (code=exited, status=0/SUCCESS)
Main PID: 3466 (code=exited, status=1/FAILURE)
Feb 27 22:56:07 s905x3anbx openvfd-start[3557]: Open device failed.
Feb 27 22:56:07 s905x3anbx openvfd-start[3557]: : No such file or directory
Feb 27 22:56:07 s905x3anbx systemd[1]: openvfd.service: Main process exited, code=exited, status=1/FAILURE
Feb 27 22:56:07 s905x3anbx systemd[1]: openvfd.service: Failed with result ‘exit-code’.
Feb 27 22:56:07 s905x3anbx (udev-worker)[3429]: event1: Process ‘/usr/bin/evrepeat -d 500 /dev/input/event1’ failed with exit code 1.
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Version: V1.4.4
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio_clk: #0 = 0x01; #1 = 0x0B; #2 = 0x00;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio_dat: #0 = 0x01; #1 = 0x0A; #2 = 0x00;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio_stb: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio0: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio1: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio2: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio3: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_gpio_protocol: #0 = 0x00; #1 = 0x00;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_chars: #0 = 0x04; #1 = 0x03; #2 = 0x02; #3 = 0x01; #4 = 0x00;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_dot_bits: #0 = 0x05; #1 = 0x06; #2 = 0x02; #3 = 0x03; #4 = 0x04; #5 = 0x00; #6 = 0x01;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: vfd_display_type: #0 = 0x01; #1 = 0x00; #2 = 0x00; #3 = 0x06;
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Detected gpio chips: periphs-banks, aobus-banks.
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: “aobus-banks” chip found. base = 496, pin count = 16, pin = 11, offset = 507
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: “aobus-banks” chip found. base = 496, pin count = 16, pin = 10, offset = 506
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio_stb evaluation (0xFF)
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio0 evaluation (0xFF)
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio1 evaluation (0xFF)
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio2 evaluation (0xFF)
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio3 evaluation (0xFF)
Feb 27 22:56:07 s905x3anbx kernel: OpenVFD: can’t request gpio of gpio_clk
Feb 27 22:56:07 s905x3anbx kernel: openvfd: probe of openvfd failed with error -22
Feb 27 22:56:07 s905x3anbx (udev-worker)[3486]: event3: Process ‘/usr/bin/evrepeat -d 500 /dev/input/event3’ failed with exit code 1.
Feb 27 22:56:07 s905x3anbx dbus-daemon[3451]: [system] Activating via systemd: service name=‘org.bluez’ unit=‘dbus-org.bluez.service’ requested by ‘:1.2’ (uid=0 pid=3469 comm=“/usr/bin/pulseaudio --system --disallow-exit --exi” label=“kernel”)
Feb 27 22:56:07 s905x3anbx dovi-loader[3532]: run dovi ‘start’ for ng
Feb 27 22:56:07 s905x3anbx (udev-worker)[3441]: event6: Process ‘/usr/bin/evrepeat -d 500 /dev/input/event6’ failed with exit code 1.
Feb 27 22:56:07 s905x3anbx kernel: EXT4-fs (mmcblk0p16): mounted filesystem without journal. Opts: (null)
Feb 27 22:56:07 s905x3anbx (udev-worker)[3486]: controlC0: /usr/lib/udev/rules.d/90-alsa-restore.rules:5 Only network interfaces can be renamed, ignoring NAME=“snd/%k”.
This doesn’t seem right.
For testing purpose I have changed the value as below.
vfd_gpio_clk=‘1,4,0’
● openvfd.service - OpenVFD Service
Active: active (running) since Tue 2024-02-27 23:08:04 IST; 1min 35s ago
Main PID: 4446 (openvfd-start)
Memory: 1.1M ()
├─4446 /bin/sh /usr/lib/coreelec/openvfd-start
└─4463 /usr/sbin/OpenVFDService -s CE21
Feb 27 23:08:04 s905x3anbx systemd[1]: Started openvfd.service.
s905x3anbx:~/.config # systemctl status openvfd.service --no-pager
Active: active (running) since Tue 2024-02-27 23:08:04 IST; 1min 58s ago
Memory: 1.1M ()
journalctl -l --no-pager Full log at
journal_1.log (153.1 KB)
Feb 27 23:07:46 s905x3anbx connmand[3759]: Skipping server 162.159.200.1 KoD code RATE
Feb 27 23:07:57 s905x3anbx connmand[3759]: Skipping server 192.168.66.1 KoD code RATE
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Version: V1.4.4
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio_clk: #0 = 0x01; #1 = 0x04; #2 = 0x00;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio_dat: #0 = 0x01; #1 = 0x0A; #2 = 0x00;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio_stb: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio0: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio1: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio2: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio3: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_gpio_protocol: #0 = 0x00; #1 = 0x00;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_chars: #0 = 0x04; #1 = 0x03; #2 = 0x02; #3 = 0x01; #4 = 0x00;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_dot_bits: #0 = 0x05; #1 = 0x06; #2 = 0x02; #3 = 0x03; #4 = 0x04; #5 = 0x00; #6 = 0x01;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: vfd_display_type: #0 = 0x00; #1 = 0x00; #2 = 0x00; #3 = 0x06;
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Detected gpio chips: periphs-banks, aobus-banks.
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: “aobus-banks” chip found. base = 496, pin count = 16, pin = 4, offset = 500
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: “aobus-banks” chip found. base = 496, pin count = 16, pin = 10, offset = 506
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio_stb evaluation (0xFF)
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio0 evaluation (0xFF)
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio1 evaluation (0xFF)
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio2 evaluation (0xFF)
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Skipping vfd_gpio3 evaluation (0xFF)
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: Select FD6551 controller
Feb 27 23:08:04 s905x3anbx kernel: OpenVFD: SW I2C interface intialized (address = 0x0000 (N/A), MSB mode, pull-ups off)
Also vfd_display_type=‘0x00,0x00,0x00,0x06’. Post which the service got started and provided the logs above. I am not sure this is is the correct value or not.
I have just changed as given below.
vfd_gpio_clk=‘1,12,0’
Active: active (running) since Tue 2024-02-27 22:56:07 IST; 2 years 2 months ago
Main PID: 3472 (openvfd-start)
Memory: 1.8M ()
├─3472 /bin/sh /usr/lib/coreelec/openvfd-start
└─3557 /usr/sbin/OpenVFDService -s CE21
s905x3anbx:~ # cat /sys/kernel/debug/gpio
Memory: 1.8M ()
I am finding the openvfd value is showing as “in hi” for gpio-506 where this was appearing as “out hi” in android. If we set ‘1,11,0’ for gpio-507 then openvfd service is not starting.
Editing this post since I can’t post more than 3 in a row
I have referred to this post and updated the flash value with above in vfd.conf.
Now the gpio showing correct entries but the values are “in hi”.
gpio-507 ( |openvfd ) in hi
@vpeter
[ 10.874965@1]- OpenVFD: can’t request gpio of gpio_clk
[ 10.874977@1]- openvfd: probe of openvfd failed with error -22
Something in the DTB is taking up pin 11. That’s why it’s not working.
I will look later tonight.
Try the instructions in this post and let me know what it does.
Thanks for looking into this. I am pasting the commands ran and the outcome
s905x3anbx:~ # mount -o remount,rw /flash/
s905x3anbx:~ # fdtput -r /flash/dtb.img /gpioleds/sys_led
Error at '/gpioleds/sys_led': FDT_ERR_NOTFOUND
s905x3anbx:~ # sunc
-sh: sunc: command not found
s905x3anbx:~ # sync
s905x3anbx:~ # mount -o remount,ro /flash
s905x3anbx:~ # reboot
Post reboot status. VFD is still not working.
s905x3anbx:~ #
Please post the dtb.img file you are using.
Please find the image I am using.
sm1_s905x3_4g.dtb (71.6 KB)
I meant the dtb.img file itself, on your box. Because the command to remove sys_led works fine on the file you attached.
I am sorry I have copied the wrong one. Please find the dtb.img from the Android for this box.
dtb.img.gz (255.4 KB)
Again, I mean the dtb.img you have in your /flash folder in CoreELEC.
Please find the dtb image from CE /flash.
dtb.img (71.5 KB)
OK, the dtb section that was causing the conflict seems to be gone.
Try with the trident vfd.conf again, reboot and post dmesg if the display still doesn’t turn on at all.
Tried with trident vfd.conf again, rebooted and tested. Still there is no display. Are the “in hi” values ok for gpio-506 and gpio-507? Do I have to modify any bits to make it high?
I am attaching the updated dmesg here.
dmesg_v1.log (73.8 KB)
